Crafts & Hobbies Logo
Sharon Posted on Oct 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My me4chsource battery candles remote no longer works where can I get another remote
Mary Petrangelo
Level 2:
Welcome Back:
Visited the website for 2 consecutive days.
  • Expert 75 Answers
  • Posted on Oct 08, 2018
Mary Petrangelo
Expert
Level 2:
Welcome Back:
Answers
75
Questions
Helped
24332
Points
183
There is a place that sells remotes for many devices..www.remotes.com
How to fix a Luminara battery operated candle that never did work?
Contact the maker direct. They aren't cheap!
LuminaraĀ® ' The Leader in Flameless Candle Technology
Luminara https://luminara.com The realistic flicker technology behind every Luminara flameless candle has whimsical roots, having been inspired by the candles created by the imagineers ...
The Best Flameless Candles
Luminara offers the best flameless candles on sale, with a bright ...
Best Flameless Pillar Candles
These flameless pillar candles are battery powered and feature ...
Flameless Candle Sets
Shop best-selling indoor and outdoor flameless candle sets ...
Clearance, Mark Downs and ...
These candles for sale won't last. Items shown below have a ...
https://www.google.com/search?q=luminara+candle
Is it cracked?
https://www.fixya.com/support/t27144145-repair_crack_in_luminara_candle
I have several 4 inch Luminara candles that no longer light, is there a solution to this problem?
If your Luminara candles dont light try reseting the timer. To reset the timer, push the power button to "OFF" setting and then push button two times at the desired start time. Candle may be used with Luminara remote control. When the Luminara candle is switched to the ON position, you are able to turn the candle OFF/ON with the Remote.
How to replace battery in fixit tools 3,000,000 candle power spotlight. Have old battery out, but wires are not long enough to attach a new battery.
I had an outfit that the wires were too short and if there is enough length cut the wire and get a longer piece of wire. and solder it together. taping the open wire.
I had one I took the connector that goes on the battery and fastened on a longer wire and soldered them together. Only do this if you understand what you are doing.
How to change batteries in remote for candles
Most remotes have a small "slide out" section on the rear, which one uses a fingernail to eject. Then inside will be the battery. Not which side is + and - and the battery type. If battery has corroded or left whits residue - a knowledgeable person needs to review & assist.
Gave flameless candles as a gift. Largest candle does not work -changed batteries.??
Were they part of a set with a remote control? If so, you will need to move it away from the others and aim the remote only at it until you can "sync" it with the others. If no remote, the bulb might have come loose in shipping. Depends on the style as to whether or not you can tighten it.
Lost Candles manual. What "On" position for timer
"your" candlelamps? Can you give me a brand / model name. I know many brands only switch off with the timer
Cannot get the remote to work
I bought 3 sets of flameless candles, remote does not work in none of them, bought new battery, still not working, one of the candles was missing the spring to hold the battery. Was there any quality control?
Remote no longer works despite changing battery, are replacement remotes available?
Usually you can buy replacement remotes, or you can buy a universal remote. What product are you trying to replace the remote too? A bit more detail and we can help better.
What are the advantages of using a battery operated flameless candle?
You can read about the benefits here
http://darrw3xxwa.jimdo.com/2011/04/25/flameless-candles-the-benefits-of-selecting-battery-operated-candles/
Sensor
your senor bar could be bad... light a candle turn off the lights and move your wii remote around until you see the little hand... be careful not to knock over the candle... if this works replace your sensor bar
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
