Hi David
I think you should replace the lamp.
SOURCE: Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
SOURCE: Hello with Sony VPL-CS1 projector in standby mode
overheated or lamp is past it's time. you may need to change the lamp, replace the lamp timer. while you're in there, clean it out.
SOURCE: Sony VPL-CX5 projector won't reset after power
Please go to menu and check auto power on if it is on make it off
