The outflows are not blocked as when I manually fill with water it drains ok. I cannot turn the dishwasher on or reset.
SOURCE: Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
SOURCE: Dishwasher will not fill with water
Bosch D/w Have a float switchin the base pan of the unit you can access by removing the toe kick, if there is water in this base pan it turns the drain pump on and will not do anything else. So until the water is removed either vacume it out , or let it evaporate or however the unit will only drain
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
SOURCE: broken dishwasher?
The dishwaser has a Anti-Flood device (a polystireene block) on the floor of the dishwaser that activates a micro switch if any small amount of water is on the floor of the washer for any reason. This switch automatically puts the washer on PUMP OUT mode and does flash the error mode and does not work. Find out what causes the water on the floor and that will be the reason for not working...
