Depends on how you have it --on a disc or usb stick or from the met
for the net go to the download for win 7 32 bit
down load and save
after that click on it and when the instruction opens click on run and let the wizard do the rest
for disc , install the disc , go to computer and click on the drive that the disc is in
if it is auto running , wait and let the wizard to the job
if on a stick
go to the computer install the stick , click on the usb listed ( removable item , click on run and let the wizard do the job
Before switching on the television put your decoder and media recorder to Standby if they are connected
and ensure the aerial is connected to your television
Select APS from Menu.
When the APS feature is selected all channels and
settings will be lost, the television will return to factory
settings and then re-tune.
* Press MENU and using the Left or Right button
select Program Table tab
** The Program screen will appear on the screen.
Press the BLUE button to start APS
*** Press the Left or Right button to set the country
**** Press the BLUE button to cancel APS or the RED
or OK button to start.
You must allow the television to complete the
search
OK.
