1. Check if your computer is turned on when charging your headphones
2. Use a direct connection instead of a USB hub
3. Try Charging the Headphones Using a Power Socket
4. Check the contact points of your headphones and charger
5. Make sure the USB cable is correctly inserted
6. Try Different USB Charging Cables
7. Check your headphone's charging port
8. Keep your headphone connected to the charging source
9. Charge your Bluetooth headphones in ideal temperatures
10. Install the latest firmware update
11. Try to hard reset your Bluetooth headphones
12. You may have placed your device in programming mode
13. Change to a new pair of wireless earbuds. Here are some recommendations: 10 Best Wireless Earbuds
If the bluetooth you are referring to is a bluetooth earbud, the batteries may be dead. You may need to buy a new earbud.
