Hi, I'm sending you the link where you can get the service manual
Hola te estoy enviando el link de donde puedes obtener el manual de servicio https://www.hifiengine.com/hfe_downloads/index.php?nakamichi/nakamichi_cr-4_cr-40_service.pdf
Check if you can open this link
Fijese si puede abrir este link
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Nakamichi-CR-4-Service-Manual.pdf
Testimonial: "Hello I clicked on your link but it will not let me into it because it says its a unauthorized link when I read it and its at the top left of this here. I'm not junking my vintage nakamichi tape deck at all and nothing today can beat it nor top it either now."
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
SOURCE: Nakamichi BX2 will not take-up tape and play
This may be a reel sensor problem, or the rotation of one of the reels is stopping for some reason. Most of the time, these faults are mechanical. There can be worn belts, or drive wheels, or gears, and etc. Sometimes there are faults in the electronics where a sensor is not being read properly.
The unit should be properly checked to evaluate the fault.
Jerry G.
SOURCE: Nakamichi CR-4 Only Recording on One Channel...need help!
Hmmm.....heres a really stupid question but........is the head clean ? There may be a bit of oxide shorting the one side of the head out. Try cleaning the head with a q-tip and some 99% pure isopropyl alcohol. If you have done that ( you seem to be more knowledgeable than most ), I would suspect either the circuit that drives the right channel record head, or the head itself. Is the head running flat against the tape?. Is there a record/play relay or record relay somewhere in the circuit ?. I think at this point you really need a schematic. Do you have the AC oscillator signal ( bias ) present on the right record head ?. I would try this first, then look into a manual.......Good luck...Rob
SOURCE: Repairing or replacing old tape decks
Hi m522posner
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
Vintage Electronics
P.O. Box 941
1241 Conestoga Creek Rd
Florissant, Co 80816
Email: [email protected]
You could have a go at freshening up the belts yourself:)
regards
robotek
SOURCE: Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
