We just purchased and Acer LCD Monitor SB220Q. I can't figure out how to attach to the base. It's almost like I'm missing a piece.
SOURCE: problems with the window mount that comes with the Garmin 360
You just have to push the ball part on the window mount into the socket part that holds the GPS. It's pretty tight, so you have to press pretty hard.
SOURCE: BROKEN MONITOR BASE
The 4 holes on the back are standard and you may find on the web, a monitor mount. You could also search ebay for the exact same monitor with a broken screen and get it very cheap and use the base off it.
SOURCE: Cannot attach base to samsung lcd monitor sw2233
Llay the monitor face down on the floor (I put it in the styrofoam from the package) and then put it up against a solid surface. Then push the part into the socket before attaching the round base.
I tried pushing down onto the monitor while holding it upright but that didn't work. When I called Samsung tech support the solution above is what they told me to try and it worked.
SOURCE: Acer X193HQL LCD Monitor Colour Problem
Hello Sales, hi, try to reconnect the VGA cable from the PC, and wiggle it a little and see if the green tinge thing disappears on screen, if it does there are loose contacts, you can also try to replace you VGA cable, see if it solve the color problem.
http://www.manualowl.com/p/Acer%20Computers/S202HL/Manual/82561
Free Acer S202HL manuals!
Problems with Acer S202HL?
Ask a new Acer S202HL question
i cant get a closer look at the diagram
how many screws did it come with
Ensure that the base is locked onto the monitor stand arm
hope this helps you
