1, You can rectify this issue by resetting the printer to its default configuration. If the error persists, follow the forthcoming instructions. Power off the printer.
2, Click Start and select Run. Type Net stop spooler and click Enter. Go to the Windows XP spool directory and delete every file. Delete the printer driver software and reinstall it.
3, Go to the Printers folder and right-click on the driver you want to delete. Click Remove under the menu. When a confirmation message displays, tap Yes. Right-click on the Printer folder and tap on Server Property.
4, Pick the driver for deletion under the Drivers tab. Click Remove and tap Yes. Now, download and install the printer driver software.
5, You can install from the installation CD or the 123hp.co link. Run the firmware upgrade by keeping the printer off. Select your printer and click Send Firmware.
6, Turn on the printer and fix the issue.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
I have seen where the download has taken out the main board....sorry
SOURCE: HP Color LaserJet 2550n
Are you using generic toners or HP branded? Try to reseat the yellow toner. The page counter can't be reset and should not be. This unit uses chips to recognize the toner level. Generic toners don't always have good chips on them.
SOURCE: Firmware updates for hp CLJ 47000dn
you can down load and software and firmware for free from HP's website.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
SOURCE: HP laser jet 1522nf mfp ( firm ware corrupt ready 2 download)
Perform the following troubleshooting in the order listed:
The Add Printer Wizard will start to copy driver files to the PC.
SOURCE: My hp laserjet M1522nf is
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
