Question about Jacuzzi Home
Spinner jets in jacuzzi hot tub not spinning - Jacuzzi Home
    Top Expert:
  • Jacuzzi Master
  • 9,900 Answers
Try moving by hand they are calcified
Posted on Nov 04, 2018
SOURCE:
  • 68 Answers
SOURCE: Bathtub jacuzzi (motor turns runs but nothing coming from jets)
Each Jet will have an adjustment many times right on the jet nozzle. Carefully try to rotate them counter clockwise to open up the jet. This assumes you can here the motor running.
Phil
Posted on Dec 09, 2008
  • 7 Answers
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
Posted on Dec 12, 2008
  • 10865 Answers
SOURCE: Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Posted on Jan 21, 2009
PartsCenter
  • 125 Answers
SOURCE: jacuzzi tub makes noise but jets wont work
sounds like maybe the impeller is just spinning on the shaft of the motor.
Posted on Feb 24, 2009
SOURCE: My jacuzzi tub motor will hum but does not run. I
I had this same problem. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is a regular screw tip, which can be used to turn the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 8 times clockwise, then 8 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
Posted on Nov 24, 2010
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Jacuzzi hot tub replacement jets
your local jacuzzi dealer should be able to source you some parts , but i can tell you if it's only a o-ring failure these are avail from your local hardware store , as most jets are rebuildable , some are not look at back for screws to see if they are or not
May 20, 2014 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Hot tub jets and heater turning off to fast
??? - turning off too fast? Problem exactly?
Are you saying that the jets don't stay on for the 15 minute cycle once you push the Jets button? If that is the case, then your circuit board is failing - the time chip is the problem. A certified Jacuzzi service center should be able to change the Dallas Time Chip.
Jan 04, 2014 | Jacuzzi Pool & Spa
Hate my jetted tub
Cover them with fiberglass cloth and tresin.
Oct 02, 2017 | Jacuzzi Home
One of the jet assemblies on my Jacuzzi 325 hot tub popped out and I can't get it to stay back in. i've been pushing it in as hard as I can but when I turn the pumps on it pops back out. Should I be...
once a jet face has fallen out of a hot tub that means the insert has failed and is broken. you will need to locate a new jet insert. Jet inserts have little tabs on them that hold them in place and when they get worn out the jet face will fall out into the tub.
Jan 29, 2011 | Jacuzzi Home
I have a Jacuzzi Z110 hot tub. the top control is broke (pn 51422). Can i use a digital top control PN 33334.
When dealing with a big manufacturer like Jaccuzzi, it is unwise to swap top side controls. They make theirs proprietary on purpose so that swapping is more difficult (especially jacuzzi).
If you use the wrong one, the buttons on the controls will be misleading (such as temp up button cycling jets, or the ozone button cycling the lights, etc)
I would use manufacturer part.
Oct 01, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
Home Logo
79 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
