Question about Hitachi Tools & Hardware - Others
My brand new Hitachi roofing nailer emits a mini whoosh of air (from the ball the trigger pushes on, I think) as I depress the trigger, but stops when it it fully depressed. Is this normal?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
It sounds like you're producing difficulties yourself by attempting to solve this problem rather than seeking at why their can be a difficulty inside very first place https://www.fliptite.com/
Posted on Oct 05, 2018
SOURCE:
SOURCE: Paslode 5300/75S Framing nailer
Soory It is a roofing nailer not a Paslode framing nailer. ended up replacing the main valve. all is well now. thanks
Posted on Sep 30, 2008
  • 125 Answers
SOURCE: won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Posted on Oct 02, 2008
  • 1407 Answers
SOURCE: brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Posted on Apr 27, 2009
smjdragonfly
  • 79 Answers
SOURCE: My brand new hitachi NV45AB2 roofing nailer leaks
Take off the back cover and make sure it's not too dry inside. Spray the inside with some WD40. You can take off the top cover. Pop the piston, cylinder, and head valve out, making sure all the seals and rings are seated correctly.Sounds like the piston is momentarily sticking. Does it shoot at all? Lemme know. Please rate me
Posted on Jun 18, 2009
airnailer
  • 109 Answers
SOURCE: dewalt angled finish nailer, just got, when nose
if air is released when the trigger is pulled then stops when the trigger is released , then the trigger is doing its job. its probably a firing valve issue. four screws will take off the top cap of the gun the firing valve is inside of the cap . first check to see if the gun has enough oil( unless its an oil less gun) if its dry then grease or oil all of the orings, if this dose not work check to see if any of the orings or plastic parts need replacing. pls rate this answer...;tks
Posted on Feb 16, 2010
Hitachi 45ab blowing air out of trigger
If air leaks thru trigger as soon as you connect airline, replace the vinyl ball under the trigger stem. If air leaks when you depress the trigger, replace the small oring on the trigger stem. If air leaks slightly from plunger in front of the trigger valve, problem is inside of the gun. Remove the head and pull the large circular plate. Replace the large outer oring. Good luck
Feb 10, 2014 | Hitachi NV45AB2 Roofing Coil Nailer
Blowing air out of trigger
Leaking under trigger could be the ball seal part # 875645 if leak starts as soon as you connect the air hose. If no air leaks when you connect hose but begins to leak when you depress the trigger then replace the oring on the plunger which is part # 874820. If air leaks when you connect the hose and the ball mentioned above is good then most likely is leaking from oring # 876161 installed on cylinder plate (remove head and pull out the plate). Good luck.
My Hitachi NV45AB is leaking air from the trigger air valve. The gun still works if I just keep the trigger depressed and just smack the tip into the shingle.
Remove the 3mm roll pin holding the trigger in place and set aside the trigger plunger (white plastic plunger should have an oring on groove). Remove the fitting that holds the trigger plunger and replace vinyl ball #875645 or check for debris under ball. Good luck with your repair.
Apr 19, 2013 | Hitachi NV45AB2 Roofing Coil Nailer
Hitatchi nv45b2 trigger leaking
Air leaking around the trigger area could be caused by vinyl ball / gasket under trigger valve bushing or orings within the gun. Easy test, remove nails and connect air (assuming that air is now leaking around the trigger area). Depressing the trigger stops the leak, replace vinyl ball. Depressing trigger does not stop leak, move plunger b (plunger B, small shaft under bubber bushing next to the trigger valve) with your finger in then out to determine if air leak changes tone. If air leak changes sound or tone, then air is leaking past orings of the cylinder guide and/or cylinder plate and/ or the cylinder itself is scratched by debris where the orings make contact. Pull out the cylinder and examine the contact areas. If scratched, use 300 grit paper to smooth, if smooth, however, suspect the orings of cylinder guide (or cylinder guide is cracked). The cylinder guide is difficult to remove and install without causing damage to guide or cutting new orings when installing. Do not remove the guide unless all the other options have been checked. One last bit if information, I have noticed that some guns will leak air if the orings on the feeder piston do not fit snuggly. Make sure that leaking sound is not coming from feeder area (remove the basket and feeder/feeder pin/spring and pull out the feed piston, making sure that the largest oring is making good contact within the cylinder). Good luck with repair.
Sep 28, 2012 | Hitachi NV45AB2 Roofing Coil Nailer
My hitachi roofing gun leaks air from trigger when not pressed
Two areas to check when air leaks from around the trigger. Rubber ball under trigger pin will cause air to leak, however when good side of the ball falls on the seat, air will not leak for a while. If air is leaking from plunger pin (just in fromt of the trigger pin), remove the head and pull out the cylinder plate to reveal broken oring (oring part # 876161). Good luck with your repair project.
Jun 05, 2012 | Hitachi NV45AB2 Roofing Coil Nailer
Air is leaking through trigger when trigger is not depressed. When trigger is depressed and nail tail cover is in safety position (holding gun in air) it completely stops. The gun fires well but there is...
could be either that or a damaged o ring, when was the last time serviced, all o rings replaced?? could be that the tool needs a thorough cleaning and new one installed. it is not hard
Aug 26, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
When I take the trigger apart and then put it back in the same way it then leaks air. I have 4 guns and I have been carefully cleaning them. Each time I take the trigger parts out and clean them and...
I believe that the most popular roofing gun for professionals is the hitachi line of nailers. Hitachi guns are amoung the very few however that actually move the cylinder when fired instead of the headvalve. This is rather odd because it requires more moving parts. Your guns have a trigger pin/plunger (white plastic with small oring part # 878-121) that pushes on a urethane ball. This ball is potential cause of leaks. Make sure that the ball is perfect. Replace as needed. Most leaks around the trigger area are acutally coming from just in front of trigger which is plunger pushed by safety foot. Spray soapy water around trigger area and make sure where air is actually leaking. If leaking from safety foot plunder source of leak is actually orings inside of gun around cylinder. (usually oring part #876-161 that fits on the cylinder plate). Parts and parts lists are at www.toolpartsdirect.com. Good luck with your guns and post again if you have other question.
Jul 29, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
My brand new hitachi NV45AB2 roofing nailer leaks air through the trigger when it is half depressed. I purchased one and returned it only to find the new one I recieved to replace it does the same thing....
Jun 03, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Tools & Hardware - Others Logo
172 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
Lance Guthrie
Lance Guthrie
Level 1 Expert
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
