Question about Bunn Coffee Makers & Espresso Machines
Bunn coffee maker model vp17-2 there is water leaking from the top
    Top Expert:
  • Bunn Master
  • 85,206 Answers
Might as well replace it, they don't really repair these.
Posted on Oct 04, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
Gord Thurston
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
Anonymous
  • 4 Answers
SOURCE: my 10 cup Bunn coffee maker leaks from the top
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Posted on Oct 15, 2009
atbsmmom
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
How to fix a leak on a bunn NHBX coffee maker
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Aug 09, 2014 | Bunn NHB Coffee Maker
Our Bunn model B10B starting leaking done the stainless steel cylinder. I took it apart. The part of the top tray between to two rubber washers had disintegrated. How do I get a new black top water...
The water tray is not available but we do have gaskets that usually will fix the leak. If you will call us at 800-352-2866 with the model and date code and we will be happy to assist you.
Sep 18, 2010 | Bunn BT10B Coffee Maker
Bunn home coffee maker is leaking from the top model #B10-W and the date code is 042302
take the top off there is a little oring where it takes water replace oring hardware store
had the same promlem
Feb 24, 2010 | Bunn 10 Cup Home Coffee Brewer
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Oct 24, 2009 | Bunn NHB Coffee Maker
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Mar 16, 2009 | Wega Mininova EPU Espresso Machine
Jan 12, 2009 | Bunn VPR Coffee Maker
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
266 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
