SOURCE: LOST COMBINATION FOR MY SAFE SERIAL #156880S-R /MODEL 5054
http://www.sentrysafe.com
the instructions are located link above.
mj
SOURCE: Besides the phone number or
Brinks safes are very reliable and secure, Unfortunately there is no way of recovering the the combination of the same without speaking with manufacture. Now you could do it the old fashion way that is to listen to clicks from the combination lock while moving the nob, However this takes alot of practice. The only the I would suggest to do is to speak with the Manufacture. I do appoligize once again and I hope you have better luck. Have a good day
SOURCE: I have The Protector model
yes you can order a new key from the manufacture or if you see numbers and letters ( key code ) on the face of the lock cylinder you can call a locksmith and they should be able to cut you the key by that code as well. if there is no code on the lock then you can have a locksmith pick it open and also make a key. either way -- a locksmith will be your fastest way to get the key.
c...
SOURCE: i locked my safe numbers
I'm
sorry if I can not give you the exact combination and I'm sure no one
does. Because that is what Sentry Fire-Safe is all about, secrecy.
However,
the best solution for your problem.... to be able to acquire the right
combination for your safe.... is to call the attention of Sentry Safe
Shop
You must call (800) 828-1438 for combination retrievals.
or
send a notarized letter stating you are the owner of the safe, personal
information, model and serial number of your safe and must indicate the
method on how you will receive the combination.
See further details from this link
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Please post back for any clarifications and let me know so I can help you further.
Thanks
Alpug
