SOURCE: 1991 N14 Pulsar SSS, disconnected
HI
IT IS FUNNY ??????????
CHECK FOR FUSE BURN OR LOSS CONNECTION ??
WITH MY BEST WISHES
SOURCE: I have a 1991 Ford Mustang GT speedo problem
check the cable for the speedometer at the interconect. the cable is loose somewhere along the length of the cable. one back of he meter, 2, interconnect. 3, transmission case.
make sure the inner cable is square not rounded. if os, you need a new cable.
SOURCE: distributor fault on toyota starlet
i have a toyota starlet turbo and when the car warms up it shuts down when i try to press on the gas pedal
SOURCE: speedometer not working all gauges work 700r4
Is the speed sensor that you are using the original one, or is it from the Camaro, or is it new for an 89 K1500?
The worm gear inside of the transmission on the output shaft that drives the speed sensor gear is not damaged?
No matter what speed sensor is installed the speedometer still reads the same?
SOURCE: i have a toyota prado 2001 turbo diesel and instum...
how to change car audio toyota prado 2001
How do I run the fault codes?
