Slide you finger down from the top of the screen. This will bring down your "menu". Tap the "Settings" (gear) icon and then tap the "A" icon to open the Language & Keyboard menu. Touch the top menu option to open the Select language menu. Select your language.
Do a factory reset.
This will let you start over. Device resets LG V30 V30
SOURCE: i have a lexmark 4800 series wifi printer...
You should be able to open your "Printers" folder, and just delete the "foreign" driver. Then just reinstall it with the correct language.
SOURCE: Language setup
After trying on my own, I went back into setting by scrolling along until a picto gram - with what appears to be a machine bolt is highlighted and then pressed SET - next the screen shows a bunch of chinese words (these are the different languages) then I scrolled down to the last one - until its highlighted, - this is the english one - press the set button on the side of the frame, this will bring you back to the english menu.
SOURCE: my mp3 player is in chinese and i need to change it back to eng.
Give this a try:
1. Hit settings icon at the bottom right of screen- box will be ticked
2. Hit the sixth box on the screen- tick box
3. There are 3 options boxes hit the first one - it is for language settings
4. Then hit the third box it says English
Hope this helps you
- Neal
SOURCE: My friend went into my settings and changed the language to China
菜单 设置 语言 英语
Menu Settings Language English
Thats a translation if your SanDisk uses symbols for chinese to change it back to english.
SOURCE: I have a new Nokia 6300. I hit the wrong key and
Just take any close model or exact of nokia handset from your friend. Settings in all the nokia models above 3500 is same just read in english at your friends mobile and click the icons on your mobile till you reach language selection option and on your mobile select english.
