Shortly after we got out machine we fixed this e24 code by shortening the discharge hose and by having a high loop before it connects to the drain connector. This fixed the problem.
Now 1 year later we have a e24 again. This time we put compressed air on the discharge hose and watched the water bubble in the bottom of the dishwasher. Turned the dishwasher of and on again on a short cycle and works fine now.
Possible causes for the E24 error code:
The drain hose could be blocked
The dishwasher filter may need to be cleaned
Brand new garbage disposal. The installer may have forgotten to remove the 'knockout' plug
After fixing the problem, reset the dishwasher according to the owner's manual
SOURCE: My bosch dishwasher starts then stops with a error
I have had a few people with the same my advice is to tell the comp. you bought it from it is under warrenty
SOURCE: Bosch Dishwasher Model # SHE6AP05UC\r\nDoes not
An error 24 code on your Bosch dishwasher means that you have a clog or that your pump is bad. Check and clean out your airgap. If that doesn't work and your machine is still under warranty, call Bosch. Bosch won't tell you what the error code means, only that you need a service call, and they will then give you some phone numbers for Bosch authorized appliance repair places, one of which was Mr. Appliance. The appliance repair place will want to put in a new part whether you need it or not so that they can get paid by Bosch. I found this out the hard way. Hey Bosch, be smart and tell your customers what the error codes mean so that they are informed and you don't look like you are trying to rip them off. Leave that to Mr. Appliance. You can always remind the customer that working on the actual dishwasher voids the warranty.
Good Luck
SOURCE: Bosch dishwasher has E 24
This means that the Dishwashers has detected a condition it needs to check.
Press "Cancel" to clear the display and to stop the beeping sound, then
try turning the Dishwashers off and on again.
If you still see the "E 24," turn off the power to your Dishwashers and wait five
minutes before turning it on again. If you hear the beep or see the "E 24 "
when you try to washing again, please call your authorized
provider for service.
Hope this help?.
Thanks for visit.
SOURCE: bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
