SOURCE: front tire on 12" Schwinn roadster tricycle
if you take it to a tire shop they should be able to fix it. as it's not a huge tire... take the rim off... fill it with air and immerse it in water to find the leak
SOURCE: Yard machine rototiller has a flat tire.
There are a couple of ways to fix the issue including, of course, the one that has been mentioned. A DIY way is to employ a tire strap. You use an inexpensive strap and ratchet assembly (commonly purchased at a hardware store et. al.). Slip the strap/belt around the tire and ratchet it until the tire bead sets. Then air the tire and listen for the bead to snap into place as it sets. If it appears that sufficient air has been pumped in, then release the strap and check the tire for leaks. Recheck air pressure and ensure it to be up to the manufacturer's specs.
SOURCE: What size tire tube goes in a 700x28c Denali Bike
700c tyres are bigger than 26".The tubes you need measure 700x28 (to32).This size is used in Hybrid style bikes.Make sure you get the same type of valve(Schreader are the same as car,Presta are narrower)or it won't fit the hole in your rim.
Make sure when inflating that the tube isn't trapped between the tyre and the rim.Only inflate to the pressure written on the sidewall of the tyre.
SOURCE: how to remove the rear tire with shaft drive
Pull the rear axle, and spacer on the brake side of wheel. Un hook brake rod and brake strut. Position yourself on the brake side of the bike and pull the rear wheel straight out of the final drive housing. Put a little grease on thhe final drive splines upon reinstalling the wheel to aid removal next time.
