SOURCE: 4150sx finder erratic depth
I had the same problem last time I was out in shallow water (in less than 2 metres of water) and I suspect that the problem was weed wrapped around the transducer but won't know for sure until I take it out on the water again. I had another problem re water temp which I'll enter separately.
SOURCE: wire on depth finder has been piched, can tou
Yes, you can. I have done it several times. Keep the separated wires fairly short. You can pick the braided (shield) wire apart with a pin or such.
SOURCE: lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth
finder unit. It accepts the two pin lead from the transducer and send
the depth reading to the dashboard display via the 6-pin connector.
There is also a three wire harness (red/blk/wht) that connects to a
power supply.
The reason I know all this is my depth finder
fried a couple years ago so I removed the Lowrance LSM-1 from the boat
in order to find a replacement. Unfortunately, this was an OEM part
that is not available from Four Winns or any aftermarket source.
Probably your best bet is to look in a boat salvage yard or purchase an
aftermarket depth finder.
SOURCE: My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
SOURCE: When we are deep water
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
