SOURCE: jag xj6 1996 97 programming the garage door openers
1.
For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.)
2.
Position the hand-held transmitter 1-3 inches away from the HomeLink surface (located on your visor), keeping the HomeLink indicator light in view.
3.
Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
Note: Some garage door openers may require you to replace step 3 with the “cycling” procedure noted in the “View Canadian Instructions” section.
4.
Press and hold the trained HomeLink button and observe the indicator light.
5.
At the garage door opener receiver (motorhead unit) in the garage, locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the garage door opener’s manual or contact us.
6.
Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step.
7.
Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
SOURCE: programming garage door opener
there are three buttons on the opener.hold the 2 outside ones down for 25 to 30 seconds to erase the program. once the light (if equipped)flash rate changes,let go.
then push any one of the the three buttons and hold it in. and then push your remote. when the flash rate changes,the code is now in the homelink transmitter.the slt and slt plus had that feature.
SOURCE: program instruction garage door opener in 2005 chrysler pacifica
if your garage motor have rolling codes you need to put your car inside garage near the motor leave ignition on go to the motor locate learn button press it then quickly go to the car and press and hold one of the buttons for approximately 30 sec or until it start blinking rapidly, if you have a regular motor take one hand held opener go inside car ignition on same time press open button on handheld remote and on the car button 30 sec and it should be programmed.
SOURCE: program garage door opener in 2005 rx 330
There are 3 programmable Homelink buttons you can use for different remotes. Just to the right of the buttons there is an indicator light.
Decide which button you want to program. Point the none battery end of your remote 1"-3" away from the Homelink panel and press both the remote and desired Homelink button down and hold them down at the same time. After about 20 seconds, the Homelink indicator light will change from a slow flashing to a rapid flashing. You can then release both buttons,
If the garage door responds to the Homelink, your done! If not, your garage door uses a rolling codes transmitter and must be trained.
Find the training button on your garage door opener's transmitter (usually mounted on the ceiling). Press the training button and within 30 seconds press and release the programmed Homelink button twice. If the garage door opener operates, you're done! If not, press and release the Homelink button a third time and the garage door should respond. If it still does not, you may have a very old garage door opener with a none digital transmitter (like I did). In that case, you either need to buy a new opener or try to replace the transmitter with a modern digital unit (as I did). Advantage: cheaper than a whole new garage door opener.
Disadvantage: The newer openers incorporate safety features that my old opener does not have.
