Kitchen Ranges Logo
Barbara Akins Posted on Oct 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to locate the oven temperature sensor o hotpoint electric stove
Chris Huff
Level 3:
Top Expert:
  • Hotpoint Master 6,289 Answers
  • Posted on Oct 03, 2018
Chris Huff
Hotpoint Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017831
Points
74913
Usually on inside back wall of oven up near top
5 Related Answers
Anonymous
  • 126 Answers
  • Posted on Dec 10, 2007
SOURCE: HotPoint Electric Stove
check your breakers check your cord make sure you have 220 volts at service block
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Nov 11, 2008
SOURCE: CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Anonymous
  • 6 Answers
  • Posted on Dec 20, 2008
SOURCE: oven temperature off
If you have a ohm meter you can ohm out the temp sensor. It has a harness that connects in the back. Unplug it and it should read around 1100 ohms at room temp. It sounds to me more like the ignitor itself. It has to draw so many amps to open up the gas valve. Check the sensor first. If it ohms out, change the ignitor. I think your problem will go away. Tenbears.
jonniewalker
Starnley Johnwells
  • 1031 Answers
  • Posted on Mar 31, 2009
SOURCE: ge stove flashes f2 and beeps
F2 is a oven sensor error . remove and or replace the oven sensor if doesn't stop replace oven control
dray8165
  • 15 Answers
  • Posted on Jul 26, 2009
SOURCE: hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
1helpful
What's causing my oven to stay hot HOURS after I've turned it off?
If you have the older type stove with the oven knob that has the temperature setting around the outside of the knob, then that part could be bad. It is called a thermostat. That part usually comes with sensor attached. The sensor is the long skinny looking tube that goes through a hole and into the oven.
If you have the newer type electronic stove where you program in the temperature you want, the electronic circuit board could be bad. But the electronic stoves have a over temperature protection built into the circuit board, so that would have engaged, shutting down the stove.
Either way, it is a potential fire hazard and needs to be addressed.
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
General electric stove not heating up
check the oven temp sensor located in the oven cavity in the upper left corner,at room temperature it should read 1100 ohms
2helpful
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
2helpful
While baking in my Hotpoint electric stove I pressed the oven light button to check on the biscuits and a code of F2 came up. What doe this mean?
this code usually means that the oven temperature is too high.
Is the oven working ok? Does the temperature seem to be correct? Did the code go away? If not,you can try shutting the breaker off to the range for a while and see if it resets. if not make sure that your oven is not getting too hot.
you could have a bad temperature sensor or possibly a bad control panel.
1helpful
I HAVE A FRIGIDAIRE ELECRTIC STOVE,GETIN F2&F3 CODES
Hi, these codes represents a fault within the oven temperature sensor. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Please rate and god bless:)
Apr 18, 2009 • Ovens
6helpful
3answers
F2 f3 starts beeping when using stove or oven
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
Open oven temperature sensor (RTD)
So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
2helpful
F2 IS FLASHING ON STOVE AND BEEPER WILL NOT STOP
F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
6helpful
Ge stove flashes f2 and beeps
F1 fault
Here are the fault code for GE:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Top Hotpoint Kitchen Ranges Experts
vince
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
