SOURCE: Harmon/kardon computer speakers bought on ebay missing power adaptor
Get the speakers with you walk a distance for your Nearest electrical shop as quickly as possible and your roblems will be solved...
SOURCE: Harmon Kardon avr 225
i copied you post and put it under harmon kardon avr 225 there's not a solution yet but someone appears to be tryng to help me
SOURCE: Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
SOURCE: harmon kardon avr 125 shuts down
CHECK YOUR WIRING!!! I have had problems from time to time, generally after re-arranging, and have found speaker wires slightly touching on 1 channel caused my AVR to give similar problems. GOOD LUCK!!!
SOURCE: Harmon Kardon AVR 235 no sound
Ensure that your speakers are connected to the terminals that you have your speaker selector switch turned to.
Then check that you have your device, whether it be a CD or DVD player, or turntable, plugged into the correct input and that you also have the correct input selected on the receiver.
