Look at the drain tube connection at the pump. Checks for leaks there. Try to check while it’s running and while it’s draining. Look for cracks in the pump.
Tub seal, water pump, hoses, or hole in tub are all possibilities.
Look under to see what is actually leaking --hose pump seals etc
Check the washer pump seal and the washer tub seal.
SOURCE: I have a Bosch washing machine /classixx 6 12 Expr...
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the
correct
type of soap so the ball check valve on the bottom of the outer drum
isn't
getting fouled with excessive suds. Also disconnect the drain hose from
your
house plumbing and let it free flow on it's own. This will tell you if
the
block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
off. Try the door gently. Means the machine is locked, for children. I think if you do
it again it locks.
