Car Audio & Video Logo
Jillian Hardwick Posted on Oct 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I find the 6 disc changer in my jeep liberty 2006
andre
Level 3:
Master:
  • Master 787 Answers
  • Posted on Oct 08, 2018
andre
Master
Level 3:
Master:
Answers
787
Questions
0
Helped
167536
Points
2382
Try the trunk ..under the front seats... glove box does it have one fitted from new it might not
5 Related Answers
Anonymous
  • 1263 Answers
  • Posted on Aug 30, 2008
SOURCE: 2006 jeep liberty
the drain plug is located on the back of oil pan in the center. if you have a rock guard you have to remove this first. the pcv valve(positive crankcase vent is located on either the left valve cover in front or on theif it's a v6 or 8 or it is located on the valve cover in the back in a straight six it will have a hose that goes to your air filter breather box or the breather hose. please rate this...........thanks
Anonymous
  • 137 Answers
  • Posted on Jan 19, 2009
SOURCE: Inoperable Power Window 2006 Jeep Liberty
the window regulator needs to be replaced
Anonymous
  • 475 Answers
  • Posted on Feb 11, 2009
SOURCE: i have a 2006 jeep liberty and three lights are staying lit and
You need to take the jeep to a dealer or a good mechanic who can retreive the codes out of the computer. You may have a module problem but I will not guess without knowing the codes.
Rob C
  • 547 Answers
  • Posted on Jul 21, 2009
SOURCE: CD Changer doesn't work after changing battery on Jeep Liberty 20
The CD changer probably failed to establish it's link to the head unit when you put the new battery in.
Since you've already tried the clear button, I'd suggest unplugging the IP-BUS cable (black cable) from the back of the changer, wait a minute (literally, 60 seconds) and plug it back in.
jason jagodzinski
  • 110 Answers
  • Posted on Feb 18, 2010
SOURCE: 2006 jeep liberty cigarette lighter problem
its probably not the lighter itself, it's probably lost power. check the fuse for the cig lighter and see if blown. if it is, replace. if it blows immediately you have a dead short. if not, pay attention to when it stops working. could be a problem with whatever you are plugging in, or something else on the circuit
LoCool light comes on when starting my 2006 Jeep Liberty Diesel vehicle. Engine coolant is not low.
coolant sensor may be faulty or contaminated coolant may be an issue. first try flushing cooling system if it hasn't been done this year.
Second, look up specifications for the coolant sensor online and test sensor with a multi meter. If faulty sensor, replace.
I have a jeep liberty w/ 6cd in the dash, when a cd is accepted into it, the machine says "ERROR".
it's been my experience that in dash changers are more trouble than they are worth, you would be better off replacing it with an aftermarket single disc player. it would be cheaper and will last longer.
Where is the "hidden button" that resets the 6 disc changer on an '05 Jeep Liberty?
This is a simple answer to yopur question it does not have one. Most factory decks do not The way you reset the unit is to unplug it from the back let it set a few minutes then plug it back it back in. Now I dont know what problem you have with your unit but that is how you reset it.
Where is the starter in my jeep liberty 05?
bottom rear of the engine at the transmission bell housing.
1helpful
2answers
3helpful
2answers
I have a jeep liberty that just had a new battery put in and now the cd changer won't work. any suggestions
Alternately, try opening the CD changer door, ejecting the CD carrier and look for a small reset button below the opening. Press this with the tip of a pen and hold it for 10 seconds, then turn the radio/CD on again.
Top Jeep Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
