SOURCE: Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
SOURCE: have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
SOURCE: Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
SOURCE: How do I re-code my Raynor Garage door opener
Open the back of the remote, change the order of the pin switches inside your remote. Then Go to receiver box ( on back on Motor) Open name plate to locate your learn button, Push the learn button, an LED light comes on for 30 seconds. During the 30 seconds, push the button on the remote and you are done
