Cars & Trucks Logo
m
miro Posted on Oct 02, 2018
Acura 2002 3.2 tl computer shoving cod P0740 - Acura Cars & Trucks
Ken Jackson
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Oct 02, 2018
Ken Jackson
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
10114
Points
64
Https://www.autocodes.com/amp/codes/p0740_acura.html
https://acurazine.com/forums/second-generation-tl-1999-2003-98/%2A%2Acode-p0740-tcc-circuit-malfunction%2A%2A-608166/
Hopefully this helps...
5 Related Answers
Anonymous
  • 321 Answers
  • Posted on Sep 05, 2008
SOURCE: transmission light cod P0740
PO740 is a TCC/lockup code.TCC stands for Torque Convertor Clutch.In between the engine and transmission is a torque convertor.Inside the torque convertor is a clutch.This clutch engages to eliminate slippage inside the torque convertor.When a malfunction occurs in the system,which is activated by solenoids,and a computer,a TCC code will set.There is a diagnostic route specifically for that code,to determine if the malfunction is electrical,mechanical,or hydraulic.
Anonymous
  • Posted on Aug 07, 2009
SOURCE: cost to replace 2002 Acura 3.2 tl transmission
your car could still be under warranty depending on the miles the car have call your Acura dealer for info. I had my transmission replaced in Feb 09 and it was done for FREE!!
Anonymous
  • 7353 Answers
  • Posted on Dec 24, 2009
SOURCE: where is the fuse box at inside a 2002 acura tl
Theres one under the hood and 2 at each end of the dash board. It would help if you told why you were looking for it. It depends what fuse you are looking for.
Anonymous
  • Posted on Feb 15, 2011
SOURCE: 2002 Acura TL low beam headlight
How to Shift my headlight beam from position.
from I replace my headlight it's spatting directly on the ground..What can i do to change it from position
Anonymous
  • 210 Answers
  • Posted on Mar 05, 2011
SOURCE: HAVE A2003 ACURA TL CODE
Hi hope I can help
You are having transmission problems
P0740 is TCC circuit malfunction. OR (Torque Converter Clutch Circuit Malfunction )
p0730 is Gear ratio in correct.
Your transmission needs major repair.
If you need more info write back.
Hope this helps
leave feed back
Thank you urnuts73@ FixYa
1helpful
2002 Acura 3.2L tl type s code P0740. What would be the next step to finding the problem and solution?
https://www.youtube.com/watch?v=ZbarS605YtE ------https://www.youtube.com/watch?v=01EwmQmSe44
2answers
Hello there my name is Clara I have a 2001 acura TL 3.2 liters thats reading the code P0740
P0740 is the torque converter malfunction code. The converter is in between the engine and transmission. The fluid that you are seeing is transmission fluid. It needs to go to a mechanic to narrow it down from there.
What's the best replacement tranny for the 2002 Acura Tl-s? I was told that honda pilot has one that makes the best replacement, but I don't know from what year or even it's true.
2002 Acura TL Recalls - Motor Trend
www.motortrend.com > ... > Acura > TL > 2002 Acura TL
Motor TrendFind complete 2002 Acura TL specifications, pricing, and photos including ownership costs, safety recalls, cash rebates, warranty, packages/options, standard features, and crash test ratings. ... Base Sedan, Type-S Sedan ..... IF DISCOLORATION EXISTS, THE TRANSMISSION WILL BE REPLACED IF DISCOLORATION IS ...
2002 Acura TL 3.2L 0-60 Attempt (Slipping Transmission ...
? 1:35
https://www.youtube.com/watch?v=fzYACqnupzk
Jun 9, 2011 - Uploaded by Intechdude300
2002 Acura TL This TL comes with a VTEC 3.2L SOHC V6 which pumps 225 HP ... That honda I had was the only one I hadproblems with. .... 2001 Acura 3.2TL Type S B7WATransmission with P1768 CPC B - Transmission ...
What is p740 cel code for 1999 acura trl code means?
If you mean P0740, it is for the torque convertor clutch circuit.
What does care code p0740 mean on a 2000 acura tl
Torque convertor clutch malfunction. Could get expensive.
DIAGRAM FOR 1999 ACURA TL TRANSMISSION SOLNIOD CODE P0740
The solenoid is inside the transmission. Not an easy task.
2helpful
Just bought a 2000 tl has these problem P0780,P0740,P1750,P1751, now what i need to do,can i fix it my self,please help me
Their all Transaxles Codes
Being 11 years old,I think you just bought
a car, the previous owner got out of, because
you need a Transaxle Rebuild.
11 years is a long time for a transaxle
May be the second round for it.
2helpful
Cost to replace 2002 Acura 3.2 tl transmission
10helpful
4answers
Acura TL remote trunk release
make sure the switch in the glove box is turned on.
Top Acura Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Acura Expert? Answer questions, earn points and help others
