Plasma TV's are very difficult to repair. You will need a power supply....and two buffer boards. The buffer boards are on the left and right. If you install the power supply only.......the buffer boards will take it down. And the Y board is not out of the question. The headache and expense is not worth the repair. I just saved your stress. By all means recycle this and buy new. Thanks for asking, Matt of Martins TV.
SOURCE: I need to find a place to buy one roland vs 2480 cd replacement fader board
You should contact Roland to find out who their parts dealer is for your area. Once you are on their site, click on the Support tab.
http://www.rolandus.com/
Jerry G.
SOURCE: need to source powerboard for
Could you post the model number please. There is no reference based upon the number you posted. It will be easier for me to cross reference based upon the model.
Thanks,
Dan
SOURCE: I have 02 plasma
The fault lies in the energy sustain boards, also called sustain boards. X-sus and Y-sus/Z-sus are the to sustain boards. If your meter has capacitance measurement capability, test the caps to see if any of them are fried. Should read OL or infinite if its bad. Try it and let me know.
SOURCE: Hi, I have Plasma TV
I have the same problem. As I see, here is dead sub PCB with microcontroller on board. Small PCB with 26 pins, mounted verticaly on main, big power supply board. It is not available as a spare part. You must buy complete power supply board LJ44-001444A, as I have done.
