Question about Nortel Computers & Internet
Nortel Vista 350 screen ghost like appearance
My pixels on the display are getting lines through them. Impossible to read. Can this be fixed? This is a Nortel 350 USWEST phone.
Find a local TV repair shop. Most can change the screen if a replacement is available. They will advise you best.
May 02, 2018 | The Computers & Internet
Message waiting light is flashing but no messages are recorded. I have turned this off at Options but message waiting display keeps coming back..what do I do.
There is a call back feature in the system. Sometimes when you receive an internal call from another extension and you are on another call the caller will hit callback. You actually have to return the call to that extension to stop the light from flashing.
Feb 28, 2014 | Nortel Computers & Internet
How do we unrestrict long distant calls nortel t7316e
i got this from Nortel expert and it works:
- press feature **266344
- user ID: 738662 Press ok
- Password: 266344 Press ok
Terminal & Extensions will appear
- press Call Timer button 1 time
write your extension or the extension you need to configure
or press find till you find the extension you need
- press Ring Again button 4 times
Restrictions will appear on the screen
Restrn Filter will appear
- press Ring Again button 1 times
Filters will appear
Normal 02 will appear ( it can be any 2 numbers)
- press CHANGE which appears on the screen
Type 00
and then press the end call button
Jan 12, 2012 | Nortel T7316E 2-Line Corded Phone
How do i program ip 2033 on nortel system
when you plug it in, and the Nortel logo appears on the screen, swipe the three buttons that are under the display, with your finger, and that will get you into programming.
you will select following
Manual DHCP config? yes
Partial? yes
enter the IP address of your system
for port #: enter: 7000
retries: enter 5
for the rest of the programming select "0" till the end
Aug 23, 2010 | Nortel Networks IP 2033 Audio Conference
Display screen on Nortel Vista 350 does not work It was working yesterday. It is not the line or the power supply I switched them It may be as simple as the equivalent of a burned out light bulb ?
Check the power adapter with a volt meter. The adapter is rated at 16 volts AC - mine puts out close to 18 volts AC.
Mine did the same thing - the right part of the phone (with the 350 on it) slides into the base - it must have come loose. I slid the part with the LCD display to the right, then back to the left (plugging it back in), and it worked (lcd and lights came back on).
If this doesn't work, and the AC Adapter checks OK, then you probably have a capacitor on the circuit board inside the phone that went bad. Unless you can replace electronic components (or are willing to send it away to be repaired), the phone will not ring, but you may still be able to answer it by hearing the other phones ring.
Jun 19, 2009 | Lands Phones
I have a Nortel 350 and the screen has become mostly unreadable but the information is still there. Is it possible to find a replacement for the slide-out screen or will I have to replace the phone?
I have the same problem. But instead of waiting around for solutions, I went inside the module and took a look. It looked interesting, lets just say that. When I gave up and but the circuit board back, RIPPPPPPP!! The little ribbon cable for the screen ripped off the circuit board. I am now devastated for now there is nothing on the screen. You can opt to buy a new module from here http://toonieshop.com/index.php?main_page=product_info&cPath=2_6&products_id=30
Jun 15, 2009 | Nortel 2002 IP Phone
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Duel boot system first xp then vista
Wow....
First I would check the BIOS settings. Make sure that the slave and master jumpers are correct on the drives.
Wouldn't it be easier to make one drive Windows XP on one drive while running Vista on the other?
It would make things easier to troubleshoot.
Jun 12, 2008 | Computers & Internet
Computers & Internet Logo
135 people viewed this question
Top Nortel Computers & Internet Experts
J John
Vuk B
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
