1, Reconnect the USB cable to the respective ports of the printer and computer or laptop.
2, Try not to connect using a hub station. Link the USB cable only when the printer prompts during the installation. Restart your printer and computer.
3, Check the front cover of the printer. There is two plastic stick that is attached to the printer. Ensure the two stick hit the two particular points.
4, Power switch connector at the left side corner and scanner sensor connector at the right side. If not, fix it out. Download and install the full-featured printer driver software that suits the operating system of your computer or laptop.
5, You can download from the 123hp.co link for free of cost. Take the cartridge out of the printer. Inspect the cartridge for damage and rectify the issue.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
Check for bad cartridge, or out of paper, possible small piece of per still jammed. Unhook the usb and see if you can print a manual test, usually depress the one of the buttons on top will print an engine test...
SOURCE: Printing problem in hP laserjet 1020
just inspect your printer's front cover.there r two plastic stick which is attached with the printer cover.this two stick hit the two particular point.
1.power switch conector(left side corner)
2. scanner sensor conector(right side middle)
i think your left side stick may be broke try it.
SOURCE: My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
SOURCE: HP laserjet 1020 driver
freee downoad from here
http://www.driverstock.com/HP-LaserJet-1020-driver-download/10-26-2954/index.html
