1, The main reason for the error is the thermistors are unable to give temperature feedback to the Electronic Control Unit.
2, The unique function of main and sub thermistors display the hot-roller temperature of the fuser assembly and gives input to control the fusing temperature.
3, Check the seven-wire connector is firmly placed in connector J405 on the ECU. You have to replace the main cooling fan to check the connection. Also, verify the four-wire connector is located in the fuser assembly.
4, Check the AC voltage is also provided to the assembly. If the error code keeps displaying, replace the fuser assembly. Also, replace the engine control board.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
High fuser temperature
SOURCE: from computer How can i scan document from HP LaserJet M3035 MFP
Hi, you must first install the scaner driver in order to scan from computer, then follow the steps from it
