This is on a Richmond RMTG64DVN system.
Gas valve resources on following link:
http://waterheatertimer.org/troubleshoot-gas-water-heater-thermostat.html
SOURCE: water heater not heating it's a richmond water heater
Now change the thermostats........this is the only other thing it could possibly be.
SOURCE: Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
SOURCE: pilot light on water heater goes out frequently
Check the following:
See if your heater has a pilot gas adjustment valve. It should be on the gas control valve somewhere. Not all heaters have these. It will be a screw on the valve that can be turned.
Make sure the thermocouple sensing bulb is squarely in the pilot flame and also check that the fitting where the other end of the thermocouple connects to the main gas valve is tight.
Check the pilot gas orifice (where the pilot gas comes out) for carbon build up - you may need to remove the pilot gas line and thermocouple assembly to get to this. This problem is pretty common.
Check the gas pressure to the heater. Run the hot water in the dwelling until the hot water heater starts. Check the flame on the main burner and see what color it is - it should be blue with possibly some yellow-tipped flames. If not, there could be a problem with the gas pressure at the heater or venting. If the heater has a gas pressure regulator, it may be out of adjustment or defective.
Finally, and this isn't very common, the pilot light can be extinguished if there is a draft problem, usually associated with an issue with the flue pipe venting system for the heater or another nearby gas consuming appliance.
Testimonial: "thank you. will try these suggestions tomorrow. really appreciate it."
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
SOURCE: New Richmond tankless water heater C8 error
I think error code C8 is #13
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Check following links to see if they have information:
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Manual shows error 05 or 13:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
