Washing Machines Logo
Lucy Parkes Posted on Sep 30, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Bosch clasixx wasting machine won't drain. I have emptied the filter, and even taken off the pipes and checked them, reassembled and it still wouldn't work. I have replaced the pump still nothing
Chris Huff
Level 3:
Top Expert:
  • Bosch Master 6,289 Answers
  • Posted on Sep 30, 2018
Chris Huff
Bosch Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019820
Points
74913
Most likely a control board issue
5 Related Answers
A
Anonymous
  • Posted on Mar 19, 2007
SOURCE: Bosch wlf2260
clean the detergent tray especially the part for the conditioner. on some bosch the rinse water valve is seperate uie different valve for water for main wsash. check valve is not open circuit resistance should be about 3.8k. could also be due to low water pressure
Simon Rankin
  • 5 Answers
  • Posted on May 16, 2007
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Anonymous
  • 105 Answers
  • Posted on Feb 24, 2008
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Anonymous
  • Posted on Aug 14, 2010
SOURCE: Hi, good evening. I have a zanussi iz12 washing
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Anonymous
  • 11896 Answers
  • Posted on Dec 31, 2010
SOURCE: machine just started leaving dirty
Check that the pump is clean and not loose. Make sure pump, impeller, and waste pipe are in alignment with each other and are clean. If it works when you shake the pipe, then there is still a clog inside or the pipes aren't aligned correctly and something is hanging up.
I have a Bosch washer that doesn't drain, i changed the pump and it still doesn't drain. Could the pressure switch be the problem. If not what can I do? Bosch 800 series
Open filter go to back of machine & clean the end of grey waste pipe blow into end of pipe, if u feel no restriction when blowing their is no blockage next tilt machine backwards at 45 degree angle against wall the u can look under washing check large black waste water pipe between bottom of drum and water pump for possible blockage make sure u isolate machine from electrical supply first hope this helps
1helpful
Well here i am,back again.Same problem kind of.yesterday we took off and descaled all pipes/filter etc.It seemed to solve the problem as the first wash worked perfectly,then on the next wash.......F18
Have you tried a boil wash ?
Also check that the drain pipe has no kinks or sharp bends in it.
I know we managed to get the drain pipe cleared :-)
But the next step may be to check that the waste pipe you are connecting to is not also scaled up.
If you can take the drain pip off again, check and see if the pipework you are connecting to is also clear.
Other than that, this may actually be a failing drain pump.
Check the rest of your pipes are clear in the house (where the machine is plumbed into).
Then do a boil wash - hottest wash you can, NO SOAP and empty drum.
Hopefully that will let the machine clear everything else out.
2helpful
DESPERATE..... Displays fault code F18 frequently.Have cleaned the filter 3 times now recently(in the last 3 days) and is very clean but stopped again.Just emptied ll washing out of it and spun it to
I would check that the drain pipe is also clear.
You can actually get a build up of old soap powder in the pipework.
This pipe would be on the rear of the machine (grey in colour) and would connect to your waste pipe (perhaps under a sink)
If you can pull the machine forward and check to see if this pipe is indeed blocked, or even restricted.
I found this answer that may help you.
https://uk.answers.yahoo.com/question/index?qid=20120322120919AANhp8H
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
2helpful
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
1helpful
3answers
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
3helpful
My Bosch Exxcel 1100 will not drain, after manualy emptying it i have opened the front filter cap checked the filter and i can see the impellar spinning but when it is full of water it will not drain
Could be the impellor is slipping under load, or there is a blockage between the pump outlet and the point it drains into the waste pipe.
Try blowing down drain hose to see if it is blocked.
Code flashing is E:18
F18 means Clean the detergent/solution pump or,check that the outlet pipe/drainage hose is not blocked.
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
  3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked or restricted.
  4. Also check that the main waste drain pipe and one way valve to a sink waste connection if you use one, is not blocked and clean if required.
  5. Access the pump from under the lower rotor arm and protective grille and check that the impeller is free to move and is not clogged or restricted by debris or sludge. Clean as required.
  6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power. It is a good idea to take digital pictures of the pump assembly before attempting to work on it or remove it so that you can refer back to it when you reassemble the unit or replace it with a new unit at a later date / time.
8. Remove and check the electrical connections to the pump and make sure they are in good order.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage. If they are then clean them thoroughly.
10. Then remove the pump and check motor is OK and that the motor turns OK. Also check that the pump impeller vanes are in good order and not blocked. If necessary replace the pump with a new and identical unit.
11. Carefully reassemble the pump observing the correct placement of gaskets, seals, O Rings, hoses and securing straps, electrical wiring.
12. Reconnect the hoses and then reconnect power and switch the machine on.
5helpful
2answers
Bosch WFF 2001 has finished a wash cycle but the water will not drain or spin away, cannot open the door. There is no apparent filter trap to empty, help!
Do the following.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
8. Check the electrical connections at the pump and make sure it is operational.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
