The turn dial on the left side of the watch pulls out ever so slightly to loosen it so it can be turned. Adjust your time and then push it back in to set the time. You need to use your thumbnail to get under the dial to extend it. One note about your watch: since it's solar powered, you need to make sure that it gets exposed to light. Don't put it in a drawer or jewelry box, and keep in mind that in the winter when you're wearing long sleeves, the watch is not exposed to light. This will deplete your battery to the point where it will no longer charge. Since you've purchased it from Costco, the service on it is excellent. I've had mine for several years and except for the above-noted battery issue, it's been great. Had a service repair, they replaced the battery, and crystal, tightened the clasp, and it's been like new ever since. No one wants to lose their contract with Costco so the service on products they sell is always outstanding. Hope you love your watch as much as I love mine.
SOURCE: Need assistence in setting the date and day on my citizen 8700 eco drive
There is an ID number I need to help you further it is the Movement Caliber number probably on the back. Once I have that I can help you further.
Regards,
Worldvet
SOURCE: Ho do I charge my
Hi leave under a strong light for a few hours, normal wearing should then be sufficient.
If only worn intermittently leave out in the light, do not put in draw or anywhere daylight can not get to the face of the watch.
SOURCE: date setting in a citizen eco-drive calibre 8700 watch
http://www.youtube.com/watch?v=RF3hC1hgZz4
hope this link illustrates u better
All the best,
Prince
SOURCE: I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
SOURCE: adjusatet time and date for my eco-drive
You can get instructions from the Citizen web site.
Go to
"citizen.com" and on the upper right there is a menu. Click on
"technical support" and then on "setting instructions"
Fill in
the information required from the back of your watch and then click on
"get setting instructions"
