Boating Logo
l
lee ketzel Posted on Sep 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Am in the process of installing a raymarine dragonfly 7 pro and need to know which wire to connect the hot wire to
Richard Doherty
Level 2:
Habit-Forming:
New Friend:
  • Expert 53 Answers
  • Posted on Mar 08, 2019
Richard Doherty
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
53
Questions
0
Helped
19535
Points
120
Below the link for manual is below
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on May 24, 2009
SOURCE: need to connect NMEA0183 to radio
Thank you for your quick respond.
I downloaded the owners manual and it had all the informaion I needed.
Anonymous
  • 3 Answers
  • Posted on Jun 25, 2009
SOURCE: Raymarine st8002 wired to furuno
Seatronix1 is correct use NMEA for the connection. Set your waypoint in the furuno, hit auto on the 8002 then track track. The 8002 will ack with next waypoint at xxxx then hit track again.
Anonymous
  • 910 Answers
  • Posted on Jul 17, 2011
SOURCE: I have a raymarine S1G
On the AR4502M the connections are as follows.
Red = 5V Supply
Black = Ground Supply
White = Signal 2.2 to 2.8V
With a multimeter/voltmeter you should be able to find which of the Red, Green & Blue Connections on your S1G give out the 5V Supply.
I'd try Meter +VE Lead to Red and -VE Lead to Green if the Meter reads +5V then the Blue must be the Signal. If not try Meter +VE Lead to Red and -VE Lead to Blue as I would expect the Red connection to be the 5V.
If you need any further help or clarifiation then just ask.
Sam H.
  • 8 Answers
  • Posted on Jan 25, 2012
SOURCE: what is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
txslim55
txslim55
  • 1104 Answers
  • Posted on Oct 03, 2015
SOURCE: Don't know where ground wire or hot wire connect to .this is a lux pro psp511a
Electric Dryers Connecting 3 Wire Power Supply Cord
I have a 96 ws6 trans am I Got a Replacement coil from dragonfly racing performance I need to know where the connector go to each plug in
ask them , Dragonfly, only they know how to use there product.
no model told , a spark coil (HV)???
where did you buy this spark coil
used or new or ?
the box had no instructions? or model number?
no photo of yours,
or if the problem is primary side
my guess is the primary connector is dead wrong for this car.
and is for some other engine or year.
HV spark coils.
Pontiac trans am. 96
THIS
5.7L V8 OHV 16V 305 HP with RAM aIR HOOD.?
IT HAS ONE HV COIL PER EACH 8 CYLINDERS
SO HV SIDE IS EASY 8 WIRES 8 PLUGS
THE PRIMARY side 12v side is fired by the PCm in its firing order.
so the harness and PCM sets firing order connected OEM.
what you have for a coil in hand I can no guess
4answers
How to hookup RL70CRC to boat wired for C70
There are 5 wires running out of the antenna and the 5 wires that you need to connect.
Where does disk go on dragonfly
Hi Kevin!
If your Dragonfly is a 6 or 7, the card door is located on the lower left of the front face.
Hope this helps you out.
-Steve
Raymarine Dragonfly
How do you connect a raymarine dragonfly to the DSC Radio
Although I could be wrong, John it appears to me that there is no NMEA output from the Dragonfly to connect to a DSC radio. Here is the link I checked.
Sorry.
-Steve
Raymarine Dragonfly
Can I enter waypoints by Lat & Long numbers on my Raymarine Dragonfly
how do you put gps marks on the dragonfly its killing me
3helpful
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
Top Raymarine Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
