Question about Janome Sewing Machines
How to thread a janome 415 machine, mines keeps breaking
  • FrankieMMijares
    FrankieMMijares Feb 26, 2019
    ? i earned $5000 last month by the use of operating on-line most effective for five to eight hours on my pc and this was so clean that i in my opinion could not accept as authentic with earlier than running in this website. if you too want to earn this type of huge coins then come and be a part of us. do this internet-website on line ...........
    g­­­o t­­­o t­­­hi­­­s si­­­te ho­­­me media tech t­­­a­­­b f­­­or m­­­or­­­e d­­­et­­­a­­­i­­­l thank you .
    copy&paste
    HERE?www.101pays.com
  • Janome Master
  • 1,030 Answers
Https://www.janome.com/siteassets/support/manuals/retired/other-models/415.pdf
Possibly debris in hook race. See section 6, Care of Your Machine. Clean and oil.
Pages 8-10 threading.
Posted on Feb 26, 2019
  • Carl Rock
    Carl Rock Feb 26, 2019
    Check top thread is not somehow snagging on rim of spool or other uneven feed of top thread. Try completely different thread and spool. Likewise with bobbin, try different thread. Comment below if same problem with different thread.
    Genius:
  • 1,256 Answers
First, check out the needle, you may need to insert a new one, then the tension and thread for the material you are sewing and make sure that the thread is not too old and that the same thread is in the bobbin and the thread on top. :-)
Posted on Oct 02, 2018
SOURCE:
SOURCE: Janome Travel Mate - Model 4612 - Need InstructionManual
JANOME MY STYLE 16S INSTRUCTION BOOK WANTED: I have just purchase this second hand sewing machine. Does anyone have an instruction manual to sell or copy? Will pay for expenses. Contact me first on frenchy31@optusnet.com.au. Thank you. Maureen
Posted on Sep 23, 2008
SOURCE: janome 1600P
My husband and I worked for months trying to solve this problem and FINALLY we did it. I even had a YLI varigated thread in the top and Coats and Clark varigated in the bobbin. The machine Janome 1600P DB makes a beautiful stitch. This is a long posting and if you have questions I'll be happy to help if I can. together425@pennswoods.net
1) I give credit to piecemealquilts.wordpress.com for their recommendations.
Most of which I list below.
2) First of all make sure that the frame is level in all directions, side-to-side, top to bottom. That includes the table that it is setting on.
3) Bobbin tension: This is much looser than you normally have it set on. The bobbin should fall steadily to the floor. Read your machine manual to learn how to loosen the tension. Be sure to go in small increments. Don't be afraid. It also helps to use a different color thread in the bobbin than the top to see the problem. Is the bobbin properly inserted into the bobbin case. Is the bobbin case properly inserted into the machine?
4)Use the correct needle for your machine.
5) Use at least a 14 and a 16 or 18 is even better. Size 20 for specialty threads if you can get a size that large.
6) Make sure that the needle is inserted properly. My machine doesn't have a flat side so proper insertion is challenging. If you can find a straight pin small enough to fit in the eye do so as this helps to determine if the needle is in at the correct angle. The eye of my needle is left to right so I use a sturdy piece of thread, some spray starch on the thread helps it to stay straight. This makes it much easier to determine if the needle is in properly.
7) The pressure foot dial is set on 0
8) The stitch length is set on the longest stitch length. I know that you actually determine the stitch length and some people tell you to have it set on 0, but I found this to work.
9)Threading: Make sure you have the machine threaded correctly. Inoticed that when my thread was breaking that the thread in the take uplever was either out of the thread guides or had crossed each other. Also, sometimes the thread had wrapped itself around the first smallthread guide and/or the outside hole on the pretension thread guide hadwrapped around the bottom of the thread guide. When your thread breaks pull a good 12" out and then cut it off assometimes it has frayed higher up. This will help to reduce continuedbreakage and your frustration. This sounds dumb but still make sure the thread is sitting on the spool properly, that the thread spills off the spool as shown in your machine manual. I found it helpful to place a felt pad underneath the spool of thread. This was just a scrap of felt with a hole cut into it. Check the retractable thread guide which is right over your spool that it is correctly positioned and not twisted around. The thread should easily pull off the spool. I found that my machine worked better if I onlythreaded the two guide holes closest to the machine on the pretension guide.
10)Thread tension: I found that my needle tension had to be much looser than what I was used to anywhere from 1 -3.
11)The quilt: Not too tight and not too loose,too tight and needles and thread break, too loose and it's difficult to move the carriage. Can you poke a finger from the bottom and grip it from the top? I found this a little too loose, but used it as a guide. The side clamps are to keep it straight and not tight.
12)The take up rail should just barely clear the bed of the machine. I found it more accurate to check this with the machine in the middle of the quilt as opposed to one of the ends. Can you fit your fingers between the quilt and the machine bed? Yes, but barely is the answer.
13) I was able to quilt in both directions, but make sure your carriage moves freely in all directions.
14) Make sure the feed dogs are down and ready for free motion.
15) Make sure the presser foot is down and ready for sewing.
16) Check both the bobbin area and the top thread tension area for stray threads. It happens.
17) My last help was to add thread lubricant, but make sure your machine allows it. I just found out that you shouldn't use this on the spool if you have plastic tension discs. Mine are metal, but still I use this sparingly. I run a couple of lines on the spool, let it sit for a few minutes then sew. I don't repeat this for at least an hour of constant sewing.
18) Strangely this also helped, every so often I pulled straight out on both the knobs of the pretension disc and the tension disc. Don't pull the knobs off. This just released the tension of the thread. I didn't adjust it, I just pulled straight out. I didn't rethread it, just released it.
19) Finally, I did discover that I had a burr on my tension disc.How to figure this out, well it works better with two people, but one can do it. Lift up the presser foot, needle is in the highest position, then manually , slowly pull the thread through the needle, listen to the tension disc. You shouldn't hear anything. Watch the tension disc, does the check spring move down? Does it stay down then bounce back up? It shouldn't. Feel the thread as it is being pulled does it have tension on it? If the answer to these questions is yes, take it to the shop and let them fix it. It literally takes 5 mins.
I hope this helps
Posted on Jan 12, 2009
SOURCE: top thread breaking during sewing.
your needle needs to be replaced and make sure it is in correctly..if this does not work you will need to make sure your thread is not old. then adjust you bobbin tension...there are 2 tensions on machine top and bobbin
Posted on May 23, 2009
  • 4 Answers
SOURCE: How to thread bobbin in a Janome 415?
Here is a link to the manual that shows how to thread the bobbin. :)
http://www.janome.com/documents/File/ManualFile/415_Instr_book.pdf
Posted on Jul 16, 2009
  • 8 Answers
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Posted on Sep 24, 2009
Janome 415 sewing machine loops on backside of material. We've cleaned and oiled the machine. We're using the right size needle, but intermittently loops form on the backside of the material.
Are you using old thread? Is the needle threaded correctly, is the thread the same in the bobbin as the top. Are the thread and needle the correct size for the material? Is the stitch length and tension correct for the material? :-)
Sep 18, 2018 | Janome Sewing Machines
I use a speed controller, medium speed. Top thread keeps fraying and breaking. Have tried changing needles, used 100/16 hlx5, 90/14, janome numbers 16, 14, 12.
When the thread is fraying at the needle eye, it sometimes means the thread is being held back somewhere in the thread path. Remove the top thread. ALWAYS RAISE the presser foot and rethread. Verify the thread path is correct. Check the tension. If it is too tight, the tensioner is not allowing the thread to advance. (When you raise the presser foot, are you able to pull the top thread?) Try changing thread brands. Some threads and machines just do not get along. AVOID old or bargain bin threads. If you are stitching coarse, abrasive fabric, it can cause thread to fray and break.
Jun 14, 2018 | Janome Sewing Machines
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
My Janome keeps breaking its thread on both of my machines-Help!
Check that the needle is in the right way - usually with the flat side away from you, but check your manual. While you have the manual out check that the bobbin is turning the right way too. Hope you fix it
First - check to be sure you have the machine threaded correctly - if the upper thread path is wrong it will break the thread every time you try to sew.
Try this link for more info:
Here is a useful document of this machine:
http://www.singerco.com/uploads/download/1300_533.pdf
Apr 13, 2015 | Janome Sewing Machines
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Where does the spool of thread go on a Janome sewing machine model 415
look for a plastic thread holder about the size and shape of a match stick with a base. It goes on the top of the machine. You see where it is if you google images for your machine
Jan 04, 2010 | Janome Memory Craft 5700
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Mar 31, 2009 | Janome Sewing Machines
The needles on my Janome 9102D keep breaking
I had a similar problem with my machine. What I've started doing with mine is setting the stitch length at 3 and the differential feed ratio at 1.0 then I set all 4 thread tensions at 3. I thread the machine from right to left, and then when everything seems to be working okay I take scrap material to test the tension and then set them to suit the material I'm using. Right now I'm working with a twill so my settings are 4-4-5-5. This seems to have stopped the thread slipping off the bottom looper and I haven't had any more needles break. I hope this is helpful.
Dec 02, 2008 | Janome Harmony 9102D Mechanical Sewing...
Sewing Machines Logo
56 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
