Question about The Office Equipment & Supplies
Hi I have a old Konica c6500 and want use it only for making booklet Is it possible to switch off the fuser? I don't need to print only pass trough and assembling booklet. Thanks for your answer.
  • 747 Answers
SOURCE:
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
  • 118 Answers
SOURCE: Instructions for Fuser Unit Change - Konica 2530DL
Send me you email at dhudson at Gmail dot com, and I will reply with the manual attached. It is a very involved process, that, having done it, would not ever want to do again.
Posted on Apr 20, 2009
Suricatta
  • 92 Answers
SOURCE: need to reset the fuser counter
Hi there.
Download Service Manual here: http://nodevice.com/manual/Konica_Minolta_QMS_magicolor_7300_Service_Manualpdf/get690.html
and follow the instructions.
Regards.
Posted on Jun 24, 2009
firecontrol7
  • 6850 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 31, 2009
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Posted on Sep 15, 2011
Konica minolta Bizhub C6500 error code 3912
This usually is a problem on the fuser lamps.
Also, you can check the sensors TH1, TS1 and TS2. Be shure about the dipsw 03-1 not be on, after fixing the fuser.
May 07, 2018 | Konica Minolta Office Equipment & Supplies
C-3102
Fusing release code drive motor for fuser or home release sensor not working . Have a tech look at this before resetting
Jun 06, 2014 | Konica Minolta C6500 C5500 C6501 C6000...
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Dec 30, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
Hi all expert, i got problem with Canon imageCLASS MF4150 All-In-One Laser Printer.the promlem is,print and copy out not clear even i replaced new toner inside..
if the problem is PRINTING and COPY, the problem will be in the fuser [FM2-8891-000] FUSER (google it).
sometimes they keep dirty sticked to the rollers and when the paper pass trough take from there.
Fosg22000 Rate Me, please
Mar 17, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Konica minolta Bizhub C6500 error code 2424
Please helpme!
Jan 07, 2010 | Konica Minolta Office Equipment & Supplies
Error code C-3505 Konica Minolta Bizub C6500
This is a fuser code, which needs reset by your service provider in service modes, let me
Dec 28, 2009 | Office Equipment & Supplies
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
