Radio Communications Logo
D
Deborah E Hallo Posted on Sep 29, 2018
My Moto E (4) Plus.0 says bluetooth is on, but says it's disconnected. It won't pair with my new Quell 2.0. Help
5 Related Answers
Anonymous
  • 25 Answers
  • Posted on Jan 26, 2009
SOURCE: how to pair moto 700 with samsung delve
moto -700s the vain of my existance. my experiance with this troublesome unit is with the boom mike closed hold call button down till light turns purple, quickly pull mike down and while still purple ( thats discovery mode) pair it with phone and if it askes for a pass key its 0000 ,and 1234 is backup key code. hope you only have 1 of these. i have 7. but they sure are pretty huh? good luck
Anonymous
  • 6 Answers
  • Posted on Mar 14, 2009
SOURCE: Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
Anonymous
  • 199 Answers
  • Posted on Jun 26, 2009
SOURCE: Pair up Plantronic 510 bluetooth with Motorola Moto EM330
put your bluetooth in paring mode
TO Lady
  • 638 Answers
  • Posted on Jan 05, 2010
SOURCE: Have new Samsung Alias 2 that won't pair to my
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
firefrozen
AYURVEDICC MEDICINE MANUFACTURING
  • 245 Answers
SOURCE: Phone disconnects from Porsche PCM bluetooth
disable the power saver option in your bluetooth, it wont get dissconnected, and add your car kit to my device menu
3answers
My Bluetooth is stop pairing with my ipad
To get help pairing a Bluetooth accessory-like a wireless keyboard-to your iOS device, try these steps:
1) On your iOS device, go to Settings > Bluetooth and make sure that Bluetooth is on. If you can't turn on Bluetooth or you see a spinning gear, restart your iPhone, iPad, or iPod touch. Then try to pair and connect it again.
2) Make sure that your Bluetooth accessory and iOS device are close to each other.
3) Turn your Bluetooth accessory off and back on again.
4) Make sure that your Bluetooth accessory is on and fully charged or connected to power. If your accessory uses batteries, see if they need to be replaced.
If you still can't pair or connect your Bluetooth accessory.
1) If you previously connected your Bluetooth accessory to your iOS device, unpair the accessory, put it back in discovery mode, then try to pair and connect it again.
2) If you can pair your accessory with some devices but not your iOS device, unpair the accessory from your other devices. Then try to pair with your iOS device again.
3) Check with the accessory manufacturer to make sure that your accessory supports your iOS device.
4) If you still have any of these issues, contact Apple Support:
You can't turn on Bluetooth or the setting is grayed out.
You can't connect any Bluetooth accessories with your device.
The accessory manufacturer confirmed that your accessory is working correctly.
Bluetooth quit connecting with Moto Razr Phone
Go to bluetooth and see what is listed click on it and remove device. Start over.
9helpful
My uniden bt108 bluetooth headset would not pair with my new Iphone4. My Iphone 4 couldn`t even recognize my bt108.
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
4helpful
2answers
Help pairing my H12 bluetooth
I successfully paired my bluetooth by going into the connection phase, just using my common sense on what to do next once I turned the bluetooth on. Since it was not paired to anything, it automatically went into pairing mode. Thanks anyway!
1helpful
2answers
Bluetooth won't connect
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
2answers
Motorola S9 bluetooth headphones
Try 0000 this is standard manufacturing default code for nearly any blue-tooth device that has security feature enabled and because the moto s9 as far as i can see has no way of being able to change this code it must be still at the manufactured setting
Bluetooth with samsung sph-640
Moto H300 should be "0000"
Motorola v3
Not being cheeky buddy but I have the same pairing are you tapping in "0000". Also go into settings and headphone or carsettings and set to auto answer. Hope this helps M8
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
