SOURCE: hi i have holden astra and i have Blaupunkt 520
Try this website
ukbookshelf.co.uk
Mention FixYa
SOURCE: 2000 Holden Astra - Hi there, I require a radio
If you have removed the radio from the car or changed/disconnected the car battery sometime back then you need Jaguar radio unlock code to get the sound back. You can purchase it from here.
There are few ways to unlock the radio
1. Refer to your manual. You must be having the code as well as the procedure to unlock it.
2. If you do not have the code then you can purchase it online. You will get the code within a day. For that you have to collect 2 information.
a. VIN - Vehicle Identification number, usually found at the bottom of the driver side windshield.
b. Radio serial number. You can get it on the top of the radio after removing it from the car.
c. You can purchase the code from here.
SOURCE: have no radio/cd codes for
Hello there, basically you can only get radio codes from 2 sources. The first being from the code card which comes with the car from the manufacturers and the second is by getting a dealer around you to help request the code from the manufacturers. Security codes are usually put into cars to deter hoodlums from stealing car stereos and this idea will not be useful if the codes for the stereos can be gotten online. The best way to get the codes are by locating the nearest dealer to you and request for the radio code also when going there ensure you have documentation to prove ownership as well as a valid means of identification. Most times the service in rendered for a stipend.
Hope this support has been helpful?
Thank you for visiting FixYa.
