Have you changed your type of coffee beans or grind setting recently? First of all I would recommend removing and cleaning the brew unit thoroughly (as per cleaning instructions) to eliminate any cleaning issue here...
This is sounds like the flush valve is not working correctly. The flush valve ensures that all unused liquid in tubes is flushed into the driptray and that all solid coffee (dry pellet) goes from the brew chamber into the waste container. At the end of the coffee cycle when the pump stops running, the piston in the brew unit usually moves one last cycle and squeezes the coffee pellet in the chamber one last time and the flush valve operates so that all waste liquid is flushed from the coffee pellet to the drip tray. If your pellet is wet, then this final flush is not working. There may be a blockage in your flush tube or the flush valve may be blocked. These usually block up if you don't run a cleaning tablet through the machine regularly.
My advice is to remove the driptray grill and check that the tubes running into the tray from the brew unit are not accidentally squeezed closed or blocked. Good luck.
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
SOURCE: mold in sharp cv-p10mc water reservoir
Dominic,
My only solution is to take the unit in for warranty service. The cooled air has a musty smell to it, too. Does yours? And did you get this issue resolved?
SOURCE: Good air pressure but pellet does not discharge.
Check your piston is still connected to the piston ram they can come apart and piston stays at front of chamber whilst the ram moves
