Computers & Internet Logo
Noor Muhammad Posted on Sep 28, 2018
Seagate st3420620as 400 gb 7200 rpm 16mb chache sata 3.0gb/s interface
5 Related Answers
Anonymous
  • 2351 Answers
  • Posted on Jul 26, 2008
SOURCE: PCI Card for SATA I VS SATA II
There are many PCI SATA controller cards out there. Just know that the SATA will not run at the SATA II standard. This is because you're motherboard may not support the bus speed for the SATA II or SATA I. If you current motherboard does not have a SATA port built on it, than your not going to see the speed the drive is able to run. Click this link (a Google search for PCI SATA II controller cards). http://www.google.com/search?hl=en&q=PCI+SATA+II+controller+cards&btnG=Search
Watch out for PCI-X. This is not the same as a PCI slot.
PCI-X slots are only found on motherboards that have SATA I & SATA II slots on them. These PCI-X slots are the smaller SATA slots found inbetween PCI-Express sloted boards.
Promise controller cards make some of the best controller cards on the market.
Mike
Anonymous
  • 1179 Answers
  • Posted on Jul 19, 2009
SOURCE: WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Anonymous
  • Posted on Oct 02, 2009
SOURCE: CDBOOT: memory overflow error.
change only CD driver
Anonymous
  • 558 Answers
  • Posted on Oct 04, 2009
SOURCE: Seagate ST3500630AS SATA 500 GB hard Drive
You will have to send it to a data recovery company in order to retrive the data sounds like the circuit board failed therefore the drive is not receiving power.Usually if this board is good you would hear the drive spin up.
Good luck
Testimonial: "Very helpful! Thank you!"
Anonymous
  • Posted on Jan 26, 2010
SOURCE: Pc saya mengunakan Motherboard P5KPL-AM SE dengan
Pc saya mengunakan Motherboard P5KPL-AM SE dengan prosesor intel Core 2 Duo 2,8 GHz, Memori VGEN 2 GB PC 5300, harddisk seagate SATA 250 GB 7200 RPM
Pc saya tidak bisa boting dan setiap dinyalakan, 15 detik kemudian mati.
saya juga tidak bisa masuk ke layar bios.
Unknown device
Samsung HDD division was only recently sold to Seagate.
"ST" is a Seagate number so your drive cannot be old - manufactured by ex-Samsung factory now part of Seagate.
Utility from Seagate (e.g. Seatools) should be able to display from S.M.A.R.T the number online hours.
2helpful
I got seagate 250gb momentus hdd which show 0mb in bios. how to rectify this error.
This is a know problem you can fix it yourself. http://howto.starahead.com/?p=61
but its tricky better to have this guy do it. http://www.allenwan.com/SeagateHardDrive.php
How to connect between sata hdd to sata motherboard
You need a SATA "data" cable, and you need to connect one of the power-connectors from the power-supply to the power-socket on the disk-drive.
My seagate barracuda 7200 80 gb having s/n: 9qz0c2zz is not recognize by my computer im using windows xp operating system
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
13helpful
3answers
Pc saya mengunakan Motherboard P5KPL-AM SE dengan prosesor intel Core 2 Duo 2,8 GHz, Memori VGEN 1 GB PC 5300, harddisk seagate SATA 250 GB 7200 RPM Pc saya tidak bisa boting dan setiap dinyalakan, 15...
1helpful
Gateway notebook model MX8711 is freezing up - i get SMART msg that hard drive is bad and needs to be replaced asap - what hard is installed in this model?
Your laptop comes with a 100 gb SATA interface HDD running 5400 rpm. Any SATA interface hard drive will do. Pay a little more and get the speed up to 7200 rpm and you can use any capacity you can afford.
The usb connector on my 500 gb seagate mseries is broken however i noticed that i can remove a plate on the bottom and replace the part my question is where can i get this part
There are 2 other solutions to this problem.
First way is to find someone that has the other module P/N 100452909 Dual FireWire 400 and use FireWire instead.
Second is to pry open the USB module and have the USB connector re-soldered or replaced. The connector is similar to many of the smart phones, so a cell phone repair shop could probably replace it. Heck you might even have the connector replaced with the newer Micro USB connector or ask them to solder the USB wire direct to the interface board.
Help
An external USB drive consists of tow parts:
a hard drive (usually a standard IDE or SATA drive), and
an enclosure
The enclosure is the box containing the drive. It also includes an interface to convert the data from the IDE or SATA interface on the drive to a USB (2) signal. Some enclosures include and internal power supply. The Freeagent has the power supply externally.
Hope that's what you mean.
Windows
I've just installed the same type of hard drive in my PC running win XP and have no problems.. do u know that you need to format the disk before it will show up with the other accessible drives?
what to do is - click start, right click on my computer and go to manage.. then double click on storage, disk management local.. and it should show up here, once you format it your all set..
No need for drivers, windows has them already, it's all generic one's the windows is familiar with..
Hope this helps!
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
