SOURCE: My Laptop won't power up
try plugging it to another same brand laptop. if the result is the same that means ur power adapter is faulty, if it's ok with other laptop then its ur laptop's power connector & motherboard is faulty
SOURCE: Does Huawei S6720-30C-EI-24S have extended slot?
Yes, Huawei S6720-30C-EI-24Sswitch supports one extended slot for 4x40GE QSFP+ interface card, it named Huawei ES5D21Q04Q01
SOURCE: Why ES5D000X4S01 Subcard cannot go up on Huawei S5700-28C-EI-24S Switch?
Because ES5D000X4S01 be used on a switch only when the switch and its rear subcard ES5D00ETPB00 run the PCB versions are VB and VC.
http://www.thunder-link.com/ES5D000X4S01_p981.html
http://www.thunder-link.com/ES5D00ETPB00_p1016.html
