Televison & Video Logo
A
Anonymous Posted on Sep 27, 2018
Do you have the codes to operate a universal Radio Shack remote, model 15-2142 for a Magnasonic DVD/VCR Dual Deck Model 825?
Tammy L Herrera
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 27, 2018
Tammy L Herrera
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
905
Points
6
Walmart has a universal remote control that works for that
  • Anonymous Sep 28, 2018
    Guess I can always try buying another remote if I have to. Just don't want to put out the money and NOT have it work. Thanks for suggestion though.
Level 3:
  • Radio Shack Master 6,688 Answers
Cindy  Wells
Radio Shack Master
Level 3:
Answers
6688
Questions
0
Helped
3532059
Points
21745
You can find the manual for the Radio Shack 4-in-1 Remote 15-2142 at ManualsLib and some other sites. A direct link to the PDF of the manual is here: http://www.rockabilly.net/files/manuals/15-2142.pdf . The ManualsLib version of the manual: https://www.manualslib.com/manual/635735/Radio-Shack-4-In-1-Remote-Control.html . The only code listed for a Magnasonic VCR is 0593. No Magnasonic DVD players are listed. If your Magnasonic DVD/VCR was built more than 6 months before the remote was programmed, then the remote has the best chance of having the correct code. The copyright date for the manual appears to be 1999.
I hope this helps. You may want to try searching through all of the codes. Many electronics manufacturers use a common supplier for the IR sensor chip and encoding.
Testimonial: "Thank you, will give it a try."
  • Cindy Wells Sep 28, 2018
    You're welcome. Cindy Wells
Kenneth Walker
Level 2:
Sergeant:
  • Expert 293 Answers
Kenneth Walker
Expert
Level 2:
Sergeant:
Answers
293
Questions
0
Helped
93310
Points
736
Most likely this unit was not manufactured by Magnavox.
Follow instructions to search for a code.
You will go through all of the codes in the remote 1 at a time to try and turn the power off. The code may or MAY NOT be in the remote,
Testimonial: "It isn't a Magnavox, but thank you any way."
5 Related Answers
Anonymous
  • Posted on Jan 02, 2009
SOURCE: code needed
Here's the link to the Radio Shack product document support. It has all the codes and how to info.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502200_PM_EN.pdf
Anonymous
  • 563 Answers
  • Posted on Feb 05, 2009
SOURCE: Universal Remote Control
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, Coby is a company whose electronics cannot be controlled by any remote other than the one that came with it. This means there is no code available for universal remotes. If you need a replacement remote (it will be identical to the one that came with the unit) please call our customer service number above. They will take your information and provide you with the procedure for ordering a part from Coby.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Anonymous
  • 12 Answers
  • Posted on Mar 14, 2009
SOURCE: looking for the code for sylvania tv/vcr combo
with most combo's try the VCR codes and then also program the tv code for the volume controls
if you are missing the programming instructions go to the RS website - support
freetek
Steve Allison
  • 5569 Answers
  • Posted on Jul 05, 2009
SOURCE: Universal remote one-for-all -need code for Magnasonic DVD 816-4C
First, you have to realize that there is no 'universal' remote; the description is a fraud. Even the type of remote that can 'learn' codes from an original cannot learn from some of them (we own one like that). They are, at best, 'multibrand' or 'multidevice' remotes.
About the only chance you might have is to check the All-In-One website for an updated list but it is unlikely that all functions of your DVD will be available with that remote.
You may be forced to buy an original remote here:
Remotes
I did not, however, see one for your 816C; only 'B.'
Anonymous
  • 217 Answers
  • Posted on Jun 09, 2010
SOURCE: i need remote control codes for a Sylvania VCR/DVD
hi! i have here a couple of codes for your sylvania DVD/VCR just try them, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095. hope this helps!!!! goodluck!!!
I purchased a universal rca remote. On the back card it listed as one of the brand name tvs magnasonic which is my tv. When i got it home there was no code listed on the paper inside for my tv. I tried...
Hi Bonnie,
I understand your frustration. RCA / Thompson Consumer Electronics has made dozens of different model universal remotes control devices. Without knowing your particular model number, it's hard to give a good answer.
I found a list of RCA codes here, and some others elsewhere - but none included the Magnasonic brand TV you have. If you have gone through the code search feature of the remote without any luck, it is probably because the TV is not supported by the RCA remote control. Not every TV, VCR, DVD, etc. is supported.
You may find that you'll have to return the RCA device and obtain a Magnasonic brand remote to operate your TV. You can view Magnasonic's Customer Support page here.
2answers
TV Remote Code
you can get here
http://www.tivocommunity.com/tivo-vb/showthread.php?t=359205
Need the set up codes to use a radio shack universal remote
There is more than one model so I do not know if your remote control operates the exact same way as this one but it is worth a try.
http://support.radioshack.com/support_video/doc66/66871.pdf
6helpful
I need remote control codes for a Sylvania VCR/DVD
1helpful
2answers
Codes for Digistar TV
code for remote filips
2answers
Our remote has been lost is there a generic one we can get to replace this?
yes go to radio shack loaded with the brand and model. There is almost always a universal remote that will solve your problem.
Where do I find an inexpensive (under $25) Universal Remote control that works with Kodak VCR/DVD player (model #DVC2010)? Is there a website that I can do a search for a compatible remote? I've alr
Radio Shack should be under $25 and there Remotes are usually made by RCA a division of Phillips, RCA is the Mfg of Most Polaroid/Kodak Audio/Visual equipment. Unless it has a lot of features, I'm sure it only uses a 3 digit remote code, If you need  a 4 digit remote code Remote it might cost you more than that. make sure you take the model # with you to Radio Shack & they will be able to tell you if you need a 3 or a 4 digit remote code remote. : )     Jay..........
I need a code for a sony remote for a maganasonic dvd player
You did not specify if is tv, dvd, vcr
try:
SONY DVD PAYER: 0533, 1533, 0864, 1033.
SONY DVD PLAYER/VCR COMBO: 0864.
SONY TV:0000, 1100, 0810
SONY TV/VCR COMBOS: 0000, 1232
MAGNASONIC TV/VCR COMBO: 1278
MAGNASONIC VCR:1278
SONY VCR: 0035, 0032, 0033, 0000, 1232, 0636
2answers
Remote codes
Radio Shack has a website for all of it's universal remote codes for the remotes it sells at www.rcinfo.com. There you'll find what you're looking for.
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
