SOURCE: Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
SOURCE: how do i make foam for cappuccino with my ascasco
On the steam pipe end their is a small hole on the side of the pipe. You should keep this hole always above the surface of the milk. When the milk rise up try to keep the hole above it. If you keep it exactly on the surface of the milk then big bubles will **** back again and become smaller and finer and your fioam stronger and better.
SOURCE: Milk container connected to machine but no light
sounds like the switch that is activated by the pitcher is not engaging correctly. try fiddling around with that a little... if not you could bypass it but it voids any and all warranty so you may want to call DeLonghi. Hope that helps
SOURCE: lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
