Question about Dacor Ovens
How do I replace the temperature sensor in the Dacor ECS130SCH wall unit? Is there a manual with diagrams showing the location of the temperature sensor?
4 Suggested Answers
SOURCE:
ginko
  • 19396 Answers
SOURCE: Dacor ECS130SCH - Both oven
If you read 0.5V with light on, then there must be something wrong, this bulbs are 12VAC.
By the way, the original part Dacor OEM 86364 is still available on the Internet, and it is cheaper than 86573. Here the part:
Ebay seller, 10 bulbs for $7.
Q10T3/CL-12V $0.41 10W 12V Replacement Lamp Light Bulb IN-STOCK
If you are not sure if a bulb has blown or not, and if the filamet does not look broken you can test the bulb using your multimeter, if the bulb reads infinity (open), then the bulb has blown.
Let me know if this solves your problem, in that case please do not forget to accept the solution.
Posted on Aug 29, 2010
oldTech2332
  • 2341 Answers
SOURCE: how do I replace the
On the bracket for the sensor is a couple screws that could be removed and the sensor could be removed from within the oven itself without having to pull the wall oven out of the cabinet.
BE SURE WHILE REPLACING THE SENSOR THAT THE POWER TO THE OVEN IS TURNED OFF AT THE CIRCUIT BREAKER
GENE
Posted on Sep 12, 2011
mc1bean
  • 3053 Answers
SOURCE: with temp set at 375 display shows temp rising
Hello, stem
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
What does a C76 or C77 error code mean on a Dacor wall oven?
Page 9-48 in technical manual excerpts at the link below:
http://www.uncleharrywizard.com/nephewclub/WizardRange/dacor/dacor-wall-oven.pdf
It says to call for service (by a technician). (I am only reading it from the document - I am not a technician.)
It says to replace glass/touchpad assembly.
It says wrong or unrecognized diode configuration.
Apr 03, 2018 | Dacor Ovens
F-1 showing on digital window of dacor dual fuel range with oven alarm beeping. Unit is turned off.
Your temperature censor may need to be replace. try geting the fault code diagram from the manufactor brand.
Nov 14, 2013 | Dacor Ovens
Blomberg BEP 906. After power went out a couple
Hello.
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
Instruction
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Thanks.
Dec 23, 2011 | Ovens
My oven flashes and beeps F 4. What does it mean?
F4 on a Dacor oven is a bad temperature sensor.
The temperature sensor is inside the oven up high on the back wall
Mar 29, 2011 | Dacor PCS130 Preference Electric Single...
Oven displays F4
The temperature sensor is inside the oven up high on the back wall.
Jan 16, 2010 | Dacor Ovens
F2 message won't stop
Look at the Diagram :-
12 is Sensor.
Thanks!!
Dec 25, 2009 | Jenn-Air Ovens
Dacor Oven F4 error message
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
May 18, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Dacor CPO130W F4 fault
f-4 on decor ovens mean the oven temp sensor is bad. replace the oven temp sensor and it will be fine
Nov 27, 2007 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
144 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
