SOURCE: Saving Bluetooth Messages in Memory Card in Nokia N73
go to message settings-- other settings---change memory in use to memory card by options... welcome-----. [email protected]
SOURCE: yahoo messenger problem
i cannot get my yahoo messanger to sign on or anything to do with yahoo to work
SOURCE: cannot see the message i typed in yahoo messenger 9 and other versions?
If uninstalling and installing the yahoo messenger also not work then follow the below two steps
STEP -1
go to Start Button - Run - type regsvr32 jscript.dll - then press OK
STEP-2
go to Start Button - Run - type regsvr32 vbscript.dll - then press OK
now your yahoo messenger will work normally
SOURCE: trouble entering message into itext sms text messenger
I updated someone else's instructions to make them more clear...
Instructions to a Sakar sms text messenger - sending text messages.
Press the NUMBERS/LETTERS below the keypad icons.
Example: SEND a message from one Messenger to the other
SOURCE: about signing in in yahoo messenger
Yahoo messenger presently is undergoing few changes at the server end. In order to login efficiently I use to run two ping commands. To do so, press on start button click on run button type cmd in the box and hit ok button. In the black window now type exactly the same in the bracket remember brackets are not included in the command (ping www.yahoo.com -t) don't forget to put space after .com before typing -t. -t is hyphen t. repeat this message once more and you will be able to login through messenger. Happy chatting
Testimonial: "hey thanks alot...!!!"
