Question about NordicTrack Exercise & Fitness
Nordictrack c2150 treadmill.After moving incline calibration failed repeatedly. I unplugged and plug every connection and put on side to take weight off incline motor, still same. HELP!!!
    Problem Solver:
  • 23 Answers
Without insulting you, I assume that you have waited long enough for the incline calibration to complete (while standing on the treadmill, say one or two minutes). I also assume that you would agree that moving the machine has somehow caused it to malfunction. Check that the new location is reasonably level and that all four "feet" touch and rest on the floor. If nothing remedies, it may be time to call a technician.
Posted on Feb 04, 2019
3 Suggested Answers
SOURCE:
AJIN G
  • 6694 Answers
SOURCE: Hello,my nordictrack 9800 incline trainer's incline is got stuck ,elevation not going up or down ,what is the procedure to calibrate the incline motor
If you wish to get some details about treadmill calibration and error code troubleshooting then check the following link.
http://electro-medical.blogspot.com/
Posted on Oct 03, 2016
Why wont my (floor model) nordictrack T9 Ci work? unplugged it and plugged it back in and it keeps going through the start up and then the buttons don't work.
Likely your incline switch is jammed or defective. Could also be that the panel circuit is defective and needs replacing. This panel circuit would need to be removed and tested to pinpoint the exact issue.
Oct 16, 2014 | Nordic Track Nordictrack T9 Ci Treadmill...
Nordic. Track incline won't work or calibrate
I have a NordicTrack C2155. Incline not working. There is a schematic inside. There are red, white, & black wires from the circuit board to the incline motor. Unplug the treadmill and have a licensed electrician construct a flying lead cord with a male spade on neutral and female spade plug on hot. Connect neutral to white and hot to where either red or black were connected. Plug in to see if the motor runs. Careful to remove power when the incline reaches its limit and reverse direction. If the motor runs in both directions, the motor is good. Follow the black two conductor wire to the circuit board and unplug from board. Check continuity across this switch. Run motor and this should toggle off and on. If all this checks out then the problem must be with the circuit board. On my treadmill, the schematic says that +5v should supply the sensor, but I only get +3.3v, which is TTL level. The drive motor sensor supply is +5v. The incline motor doesn't even show a sign of trying to run. Either the output transistor is burnt out or the low voltage caused an error so that it does not try to run the motor. Either way, I'm quite certain that a new controller board will remedy the problem.
Jan 09, 2012 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
Kettler atlantis 51L error!!!! what is the solutions?
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
Aug 17, 2011 | Exercise & Fitness
On my nordictrack a/2350 the incline stoped working what could be wrong?
Follow the instructions found in your manual for incline calibration first. With the safety key/magnet in, press incline up, remove the key while the numbers are changing, release the incline button then reinstall the safety key. The incline should calibrate.
If the motor moves, then stops b4 completing it's cycle, the incline sensor may be defective. The sensor is the black cap/wire coming out of the top of the motor. Make sure it is connected properly.
If the sensor is defective, you have to order the complete motor to repair the problem The sensor can be replaced without replacing the motor, but it is not available as a replacement part..
Part #249516 around $110....
Dec 15, 2010 | Nordic Track NordicTrack A2350 Pro...
Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Exercise & Fitness Logo
126 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Ross Metcalfe
Ross Metcalfe
Kardoc
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
