Car Audio & Video Logo
chris Posted on Sep 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have amp hooked up but it only works on tuner it shuts off if use auxiliary to my phone
Alphanso Tee
Level 2:
New Friend:
  • Expert 169 Answers
  • Posted on Jun 16, 2019
Alphanso Tee
Expert
Level 2:
New Friend:
Answers
169
Questions
0
Helped
141759
Points
280
Auxiliary have a shorts
check you aux connection''
Sony CDX-M850mp isnt playing any audio from aux or cd input. when I hook it up, the tuner works fine. the cd player reads and plays through the cds but there isnt any audio. weirdly, the button beep noise...
This issue might be due to a malfunctioning auxiliary input or a problem with the amplifier circuit. You can try the following steps to troubleshoot the issue:
  1. Check the connection between the auxiliary input and the head unit to make sure it's properly plugged in.
  2. Check the audio cable for any signs of damage or wear.
  3. Make sure the auxiliary input is selected as the source on the head unit.
  4. Check the amplifier circuit to see if it's functioning properly. If it's not, the amplifier may need to be repaired or replaced.
If these steps don't resolve the issue, it's recommended to have the unit inspected by a professional audio technician.
How to hook up a power amplifer to my jvc receiver using rca plugs
RCA or Phono type plugs only have a single pin plus ground and so one plug and lead assembly is needed for each channel..
It is important to match the output of the tuner to the input of the amplifier. This is easy if the amp has a dedicated tuner input but if it hasn't it is best to study the instructions, though at a push the line-in or auxiliary input might provide satisfactory reproduction.
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
3helpful
My HDMI inputs #2,3, & 4 no longer work. I have my Direct TV hooked up to the #1 & my Playstation 3 hooked up to the #2. The # 1 still works, but the others don't. Idid try all of them out also....
Unplug the tv about an hour to let it reset itself.Replug,reset everythings in ur tv menu back to factory setting.All ur functions on the Tuner board should work again.Not than,ur Tuner board is defective,have all those shorted HDMI input Hubs.The only way now it to replaced the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
2helpful
2answers
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
1helpful
Amp shuts off when trying to play cd
it sounds like you have the amp hooked up to the power antenna lead instead of the amp remote lead. should be two blue wires.
2helpful
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
No Subs in CD mode??
Ah, common problem. You hooked up the remote turn on wire for the amp to the power antenna wire (solid blue). Hook up the remote turn on wire for the amp to the blue wire with white stripe. The power antenna only provides power when the deck is in tuner mode for the power antenna to be extended, intuitively, and cuts power in any other mode, because certainly it's only needed for AM/FM reception.
Top AMP Car Audio & Video Experts
littlewheel
Steve Sweetleaf
Steve Sweetleaf
Alexander
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
