SOURCE: Unable to set time and date on a vestal G5 global traveler watch
Not sure if you found your answer or not but I managed to locate the manual on the Columbia website. Here it is in case you haven't found yours yet:
http://www.columbia.com/images/PDFs/customer_service/ColumbiaLeaflet_7-05.pdf
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: how to set time and date on digital watch have lost the manual
de button on the side of the watch got 3 stands:
- totally to the left is nothing
- totally to the right is set time/hours/days
- in the middle set date.
Hope this helps
SOURCE: Watch setting instructions SEIKO 7N43 8A39 "A1"
If you are still wondering about this, pull the knob out to the first click. turn one way to set day, turn the other way to set date. Pull out further to set time.
