SOURCE: setting up a laptop to use its tablet pc functions
XP Pro should run fine on it - I would assume that is what it came with. You may need to download additional drivers from Toshiba. I would check with Toshiba about the pen as well, but without it should still function as a regular laptop.
SOURCE: Why does my tablet keep showing 'data connectivity
this problem allways shown when your tablet have lots cache file so plz update you tab or give small reset soft reset its totally easy just off your tab press down vol button and press home button and press power button after few secound you saw one blue screen shown and some option came 1<formet<2hdd recomded so plz press 1 when you press one you see you tab take some time and you seem few munite latter reboot it and your problem solved
Testimonial: "Thank you so much. Just by re-setting it, it worked. I leave it on stand by all the time, so probably had not had the chance to update etc. I,m not good with technical stuff. But. Thank you again"
SOURCE: i cant get my polaroid 7" tablet powered by
Maybe try going to the router settings and changing the security settings. See if turning off wifi password solves the problem then turn it back on.
They are.
Testimonial: "thank you."
