Looking for a firmware update? Perhaps there is not a current one. However, you can inquire:
https://jvcsmart.com/pages/support
The following JVC support page did NOT list such:
http://support.jvc.com/consumer/custrel/index.jsp
You might take a look in your system menu. It may have an update menu item. If it does, it likely expands to particular models. If yours is not listed, there may not be an update available.
Testimonial: "Thanks for the assist Don A. tv wont update tho"
SOURCE: jvc tv
Phoned shop where I bought tv. Talked to service team and they talked me through how to solve the problem.
regards Jill
SOURCE: JVC LT-42DA8BJ
How are you connecting your laptop to the samsung TV? Is it DVI/HDMI or thru more-common S-video cable? I have successfully ported laptop screen to TV with S-Video. After you connect your S-video cable, right-click on blank desktop of laptop and bring up the Display Properties (usually the last entry on pop-up menu). Got to last tab, usually called Settings. You should see two monitors displayed on top part of this page. One of these (most likely #2) is your TV. Click on #2 monitor and check the box that reads "Extend my Windows desktop to this screen" (or words to that effect). Be sure you have the TV turned on and facing you because you may find yourself clicking on icons on the TV screen. You'll probably have to play with which is primary display because some video players have trouble playing to a secondary screen. You may also try the Fn+F8 (CRT/LCD) button on your laptop (those are the keys on my Dell). That may turn on the TV-out on the laptop. Lastly, remember that this will only get you video. You'll have to connect a 3.5 mm cable to you Line-Out port on the laptop and connect it somehow to your TV or SurroundSound speakers. There should be a audio-in port on those other devices for that. Or you can just play the sound thru your laptop speakers.
I'm not that familiar with the DVI-out but I suspect that it would work very similiarly. Good luck.
SOURCE: I need the USB firmware
Unplug TV, Plug back in. Hold menu and -vol buttons. Push power button and release it. keep holding the 2 buttons for 5 sec. release both button and TV should come on.
SOURCE: Hi, I need a user manual for jvc tv LT-32TW51J
http://www.jvc.co.uk/files/instruction_manual/lct2016-001b-u.pdf
Try this link to download the manual.
Gopakumar Gopalan Google
