SOURCE: Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
SOURCE: how to bypass a park switch for a jensen model VM9212N
go to settings menu, and highlight language button. and on your remote enter 543210 in sequence. then another menu will pop up. Go to the settings menu and then the second one down will be the brake option. then click which setting you want
SOURCE: 2008 crysler town and country dvd player
While in park, get the movie playing. Then press on the "Audio" button. This is the button that displays the speaker balance (front, back, left, right). While the audio display is still showing, put the car in drive (or reverse to back out and then drive). Once you are underway, press on the "Audio" button. The video will continue to play up front while you are driving. You have to do this each time, but its not that big of a deal. Obviously this is for the front passenger's use, and not intended for the driver.
SOURCE: Jensen Phase Linear uv10 dvd wont play while driving
When You installed it the pink wire that said to brake did you put it to an actual ground instead of the barking brake?
