Cell Phones Logo
C
Crystal Posted on Sep 24, 2018
What are UPLMN Settings? - Cell Phones
2answers
Ps3 was owned by someone else and they put a block for mature games how do you get the block off
Unless you know the password they used you would need to completely re-initialize the unit as it was a new one, from the beginning, to wipe it out completely and set it back to factory defaults (sledge-hammer reset).
There is no way I know of to retrieve this lost password if you do not also know the owner's PSN information, which I'm sure you cannot get to. You might Google the question.
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' [email protected] ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
2helpful
Am a sony e w660i user , i cant able to receive internet settings
If your phone misses the Internet settings at purchase, you can easily download the settings directly from your phone. If your phone can´t download the settings, contact your network operator.
To run Settings download:
Go to Settings > Setup wizard > Settings download and press "Select"
Note:
The first time you start your phone or insert a new SIM card, the Settings download is triggered from the start-up wizard.
You can run Settings download as many times as you like from the Settings menu.
2helpful
Hi all the settings in the mms profile have disappeared and now i can't send or recieve pictures.hope you can help
hi..
Changing MMS settings:
  • To Change MMS settings:
    • Goto Multimedia messages Menu > Settings
    • Select Setting category and change the settings.
  • if you follow the steps you can easily got it..
  • thank you.
  • If it's useful for you means plz rate me the 4 Thumbs ....
2helpful
MY PHONE IS LOCK AND I CANNOT UNLOCK IT. WHAT CAN I DO?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/t-mobile-phones/SGH-T929ZKATMB/index.idx?pagetype=prd_detail&tab=support
Page 165 from your manual:
Reset Settings
From this menu you can reset your phone and sound settings to the default settings or perform a Master reset.
Reset settings
1. From Idle mode, touch Menu ➔ Settings ➔Reset settings ➔Reset settings.
2. Touch the check box next to each of the following that you want to reset
• All: Phone, Display, and Sound settings are returned to default values.
• Sound profiles: only sound settings are returned to default values.
• Display settings: only display settings are returned to default values.
• Phone settings: only phone settings are returned to default values.
3. Touch Reset.
Master reset
From this menu you can reset your phone and sound settings to the factory default settings.
1. From Idle mode, touch Menu ➔ Settings ➔ Reset settings.
2. Touch Master reset, enter your password, then select Yes to confirm.
The phone resets to the factory default settings automatically and when finished displays the Main menu.
Hope this helps, let me know if I can do anything else for you.
JimmyC
My playstation will not read dvd's and just recently stopped reading games. I'm just wondering how to reset the entire system
  1. From the XMB™ home menu, go to icn_settings.gif(Settings) > icn_syssettings.gif(System Settings) > [Restore Default Settings].
  2. Once you select [Restore Default Settings], you will see a list of settings that will be restored. Scroll through them and press the icn_btnx_color.gifbutton to restore the settings.
  3. After the operation is complete, you will see the initial setup screen that appeared the first time you turned on the PLAYSTATION 3.
    You will need to go through the initial setup process before you can use the PLAYSTATION 3.
IMPORTANT
The Restore Default Settings feature will erase any previously saved settings and restore all of the following settings to the default:
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Date and Time Settings
  • Accessory Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
  • Internet Browser Settings
Read this next paragraph carefully!!!!!!
Also, do not confuse "Restore Default Settings" with the "Restore PS3 System" option (the next option down on the menu). The "Restore PS3 System" will not only restore the default settings, but it will also delete all hard disk content. (You will lose all saved content from your PS3 system's hard drive if you use "Restore PS3 System.)
Error code 80010514
Sony has a few fixes for this.
Visit PLAYSTATION 3 System Software Update to download and install the most recent version.
To check what version of the System Software is currently installed on your PLAYSTATION 3:
  1. From the XMB™ home menu, go to icn_settings.gif(Settings) > icn_syssettings.gif(System Settings) > [System Information].
    The system will display the System Software version number.
OR During certain troubleshooting situations, it may be necessary to restore all of the PLAYSTATION 3 system settings back to their original "default" configuration.
IMPORTANT
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
OR
Power-Cycle All Network Equipment Power-cycle means to turn the networking devices OFF (i.e., unplug it from the power source), and then to turn it back ON after a set period of time. This will allow the network devices to refresh its settings.
Please power-cycle ALL of your network equipment, including any wireless access points, routers, Voice Over IP (VOIP) modems, and broadband modems for two (2) full minutes. After 2 minutes, you can turn on (or plug in) your equipment.
Hope this helps. Good luck and happy gaming!! // //
1helpful
Parental code
Try to reset the PS3 by holding down the power button for at least 5 seconds. Otherwise, you can try this:
1. From the XMB home menu, go to icn_settings.gif (Settings) > icn_syssettings.gif (System Settings) > [Restore Default Settings].
2. Once you select [Restore Default Settings], you willsee a list of settings that will be restored. Scroll through them andpress the icn_btnx_color.gif button to restore the settings.
3.
  1. After the operation is complete, youwill see the initial setup screen that appeared the first time youturned on the PLAYSTATION 3.
    You will need to go through the initial setup process before you can use the PLAYSTATION 3 again.
IMPORTANT
TheRestore Default Settings feature will erase any previously savedsettings and restore all of the following settings to the default:
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
Also,do not confuse [Restore Default Settings] with the [Restore PS3 System]option (the next option down on the menu). The [Restore PS3 System]will not only restore the default settings, but it will also delete all hard disk content. (You will lose all saved content from your PS3 system's hard drive if you use [Restore PS3 System].)
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
